Re: R5 P7 question with pictures
[Re: mafo]
#1258136
06/28/12 06:00 PM
06/28/12 06:00 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
Bill Harris picked up considerably going to the Bruno G force over the powerglide.
It sure looked like you were having a lot of fun Ken shifting gears.
I understand the concept of having to apply T-brake to get the trans in gear. Just like the input shaft brake on a big truck. You either have to be rolling or push the clutch to the floor to apply the brake or it aint going in gear. Rrrrrgh Rnnngtt Rgnnnttt-tt
Don't really understand the reasons for the fourth gear deal not wanting to come out of gear. I assume the converter is turning the input and not wanting to quit after a burnout. The driveshaft has almost or stopped and everything is jammed with stored energy. Bump the Transbrake to stop the input shaft and the tranny will let go of fourth gear. Does this make sense?
[Re: Leon441]
#1258137
06/28/12 06:31 PM
06/28/12 06:31 PM
Posts: 1,019 Finland
mafo
Finland
fourth have a different slider than the others, it will pop out of gear in a no load situation only, you will have engine braking in 4 gear and when you drive around the pits you use 4 gear ![](/ubbthreads/images/graemlins/biggrin.gif) once you have stopped the car with fourth engaged the only way to get neutral is to shut the engine down, the tb trick only works if the car is still rolling, slowly that is, to much speed and it will lock up the rear wheels when the slider don t have time to find the "window" I make my burnouts in third to avoid the hassle ![](/ubbthreads/images/graemlins/wave.gif)
-65 Valiant,420", all motor,2700#, dot tires, 8,42 @ 160,2
[Re: Leon441]
#1258138
06/28/12 08:36 PM
06/28/12 08:36 PM
Posts: 4,421 in a chair
mopartony
in a chair
Ok so you are saying when I go through the traps and let off the gas, the trans will not neutral out that I have to blip the throttle to get it to neutral out? Just wanting to make sure.... Also if I am doing a rolling burnout I can 3-4 shift and not have to worry about sticking in 4th? it will neutral out? then reverse back? I feel like such a newb. This is getting way complicated. Clutch please!!! ![](/ubbthreads/images/graemlins/laugh2.gif)
[Re: mopartony]
#1258139
06/29/12 05:11 AM
06/29/12 05:11 AM
mafo
Finland
you will figure it out ![](/ubbthreads/images/graemlins/thumbs.gif) I have been thinking about a clutch lately ,according to the clutch guys my car would fly with a clutch ![](/ubbthreads/images/graemlins/biggrin.gif) , but I m not so sure...
[Re: mopartony]
#1258144
06/29/12 04:52 PM
06/29/12 04:52 PM
mafo
Finland
I know there is some computer programs that help someone like me that have no idea how to set up a clutch, but it would still be a steep learning curve, a lot of money and probably more work than it s worth well, maybe I will have a real race car someday ![](/ubbthreads/images/graemlins/biggrin.gif)
[Re: mafo]
#1258145
06/29/12 05:22 PM
06/29/12 05:22 PM
mopartony
in a chair
Your car is nice already. no worries there!!! I crewed that car for 4 years, trying to learn everything I could. The clutch was the hardest. Between reading the track, guessing what the track is going to do and getting the rest of the car set correctly. I learned enough to be dangerous.... ![](/ubbthreads/images/graemlins/laugh2.gif) In the end the only thing I didn't do was make the final call on adjustments to the clutch. I was asked every pass what I thought.
[Re: mopartony]
#1258146
07/01/12 09:33 PM
07/01/12 09:33 PM
Posts: 4,027 Dearborn Hts, MI
Sledge_57
Dearborn Hts, MI
I missed something Tony, what car is this going in?
Doug
1967 "Pedal Car" 500" low deck , TF 727, 4.30 Locker Best to Date: 11.67 @ 114.9 1.64 60ft
"Kids in cars cause accidents. Accidents in cars cause kids..."
