Good locksmith? #1257380
06/25/12 10:52 PM
06/25/12 10:52 PM
Chino Valley
RodStRace Offline OP
Chino Valley
I picked up a complete set of A-100 locks and ignition at the yard today. They didn't come with a key , but the van appeared to be not heavily messed with so I'm hoping they are all the same.
These lock cylinders are the same as 61-64 dart, meaning they cannot be rekeyed.
Is there a Mopar expert locksmith that could make a key to work these?
P.S. I asked the local places and they don't do this. They can only make new keys from an old one...
Re: Good locksmith? [Re: RodStRace] #1257381
06/25/12 10:58 PM
06/25/12 10:58 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
are there codes on the locks?
Re: Good locksmith? [Re: 6bblgt] #1257382
06/25/12 11:05 PM
06/25/12 11:05 PM
Chino Valley
Chino Valley
Nothing visible. I haven't cleaned them up fully yet, I did scrape the top of one and the side of another.
Here's a pic (the other side door cylinder is still in the complete door I bought too).
I obviously can't remove the ignition cylinder without the key or damage (it has the pin you push under the nut, but you have to turn the cylinder to align the hole to the pin).
Re: Good locksmith? [Re: RodStRace] #1257383
06/25/12 11:06 PM
06/25/12 11:06 PM
central Florida
VL21 Offline
VL21  Offline
central Florida
There is a chance that on the side of the lock body there is the key code, and a locksmith will be able to make new keys from that.I just went to look at some of what I have, some are, some aren't.
Snoozed and lost...
It takes gasoline to interest me.
Re: Good locksmith? [Re: RodStRace] #1257384
06/26/12 01:28 AM
06/26/12 01:28 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Those can most certainly be rekeyed. The top plates are staked in, but they can be removed and restaked. Any REAL locksmith can perform this operation. You've been talking to key monkeys...
I'm not a real locksmith, but I could figure it out and probably get a key cut. I can tell how the good locksmiths do this without taking a lock apart, but you need a fresh uncut key. There are marks inside the lock that can be transferred to the new key by inserting and pressing the key against the sides both ways, sometimes...
Re: Good locksmith? [Re: Jim_Lusk] #1257385
06/26/12 01:47 AM
06/26/12 01:47 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
If you can get the ignition picked and get the code off of the cly, then you can get a key cut with the number on the cly( provided that the cly has not been rekeyed). I bought the OEM stuff from the local dealer and can cut a key from the code by using a book. Any locksmith can do the same.
Re: Good locksmith? [Re: fastmark] #1257386
06/26/12 02:28 AM
06/26/12 02:28 AM
Bowie, MD
Reggie Offline
Reggie  Offline
Bowie, MD
Ditto. I pulled a complete steering column and matching door cylinders at a yard. Took one of the cylinders to a locksmith and they cut a key for it.
Re: Good locksmith? [Re: RodStRace] #1257387
06/26/12 08:37 AM
06/26/12 08:37 AM
Puttin' on the foil in Charles...
not_a_charger Online mad
Mr. Big Shot Moparts Moderator
not_a_charger  Online Mad
PM member Hoof Hearted. He's a locksmith.
Earning every penny of that moderator paycheck.
DBAP
Re: Good locksmith? [Re: RodStRace] #1257388
06/26/12 08:53 AM
06/26/12 08:53 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I agree find a good lock smith.My 57 when I got it only had an ignition key.Took it to Allied Lock in Youngstown.He pulled my trunk lock cleaned it made me 3 keys for it and the glove box.He also made me 2 spares for ignition.Total cost was about 25 bucks.Rocky
Chrysler Firepower
