Re: E-body shifter in an A-body, anyone ever do it?
[Re: BADBEE]
#125675
09/24/08 02:19 PM
09/24/08 02:19 PM
Posts: 3,106 Ridgeland Wi
mopars_1
Ridgeland Wi
your just wanting to put the slap stick into the a- body correct? keep in mind also, e-bodys had a shorter handle than the a-body and might be a little awkward shifting when its in the car. other than that, I would bet that it would bolt in. also check the outer chrome and shift pattern area to make sure it fits nicley threw the console
1971 Plymouth Duster 340 auto 1937 Plymouth PT50 1969 Dodge Dart Swinger 340 4 speed 2013 Ram laramie 2500 hemi 2008 Harley FLSTSB springer
[Re: mopars_1]
#125676
09/24/08 03:09 PM
09/24/08 03:09 PM
Posts: 9,982 Ansonia, CT
CJK440
Ansonia, CT
The console in my Duster hides a B&M Quicksilver ratchet shifter with a stock appearing stick coming out of it. You'd never know unless you tried to drive it.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
[Re: Jim_Lusk]
#125686
10/03/08 01:12 AM
10/03/08 01:12 AM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Like I said before the total throw is different. It would not be hard to measure and adjust, though.
Jim, I think the easy solution would be to see if you can just use the E body torque shaft.. (the shaft that passes through the floor & connects the shift rods to the shifter & trans) as it would have the proper geometry...
