E-body 22" radiator installation... #1256744
06/24/12 10:26 PM
06/24/12 10:26 PM
Houston, Tx
hemi68charger Offline OP
Houston, Tx
Hey Gang,
Figured I'd run this by you. I've started the process of getting my buddies '71 back together. I'm a learnin' when it comes to the E's. I'm installing a 22" radiator in my friend's '71 Challenger R/T v-code. Someone at one point in time installed a 26" radiator which is incorrect. We found a 22" for a '71 E-body, but it is for a 383.. Right now, no biggie, it fits... There is a slight complication that the top of the fan blade slightly hits the shroud at the top. The fan blade as an intention that looks as if it is there for clearance of the shroud. Looks like the car has been hit as some point in its life. The driver's side upper mounting point for the radiator looks like it's bowed backwards and the radiator upper transverse support looks bent. Maybe it is a case of things ever so off it causes the fan to rub the shroud. Also, maybe, just maybe there's a different fan I need? What is the length of a viscous fan blade on a car equipped with a 22" inch radiator?
Any of you guys out there with a 22" radiator, what is the gap measurement from the back of the core support to the top tank front face. I can use that as a start of tweaking and fixing.....
Thanks..
Troy
Troy
Houston Mopar Connection Club
Re: E-body 22" radiator installation... [Re: hemi68charger] #1256745
06/24/12 10:27 PM
06/24/12 10:27 PM
Houston, Tx
Houston, Tx
another. Fan is position this far out of the shroud?
Troy
Re: E-body 22" radiator installation... [Re: hemi68charger] #1256746
06/24/12 10:27 PM
06/24/12 10:27 PM
Houston, Tx
Houston, Tx
1 more> Top of fan blade rubs against the shroud ever so slightly
Troy
Re: E-body 22" radiator installation... [Re: hemi68charger] #1256747
06/24/12 10:28 PM
06/24/12 10:28 PM
Houston, Tx
Houston, Tx
2 more
Troy
Re: E-body 22" radiator installation... [Re: hemi68charger] #1256748
06/24/12 10:28 PM
06/24/12 10:28 PM
Houston, Tx
Houston, Tx
3 more: vertical portion of core support at upper driver's side mounting point doesn't seem to be true. Looks as if the car's been hit during its lifetime. Maybe this, along with what appears to be a curved upper core support could have negative effects on the radiator-to-shroud/fan positioning.
Troy
Re: E-body 22" radiator installation... [Re: hemi68charger] #1256749
06/24/12 10:28 PM
06/24/12 10:28 PM
Houston, Tx
Houston, Tx
4th
Troy
Re: E-body 22" radiator installation... [Re: hemi68charger] #1256750
06/25/12 12:38 AM
06/25/12 12:38 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
I'm not sure if 22" radiator cars had fan clutches.
383 b & ebody combo: 3443961 radiator, 2120510 spacer 1.60", 2863224 7-blade 18" dia. fan, 2998328 shroud
The shroud was designed for a 18" fan, if you have a 215/216 they're 18-1/2".
Re: E-body 22" radiator installation... [Re: 6bblgt] #1256751
06/25/12 08:26 AM
06/25/12 08:26 AM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
They used a fixes fan and spacer..
MB
Re: E-body 22" radiator installation... [Re: HPMike] #1256752
06/25/12 08:39 AM
06/25/12 08:39 AM
Houston, Tx
Houston, Tx
Thanks guys.. Anyone with a picture(s) of the configuration? I'd like to see with my eyes. Would the previously mentioned configuration also apply to a 440+6 drivetrain?
Cheers,
Troy
Re: E-body 22" radiator installation... [Re: hemi68charger] #1256753
06/25/12 09:59 AM
06/25/12 09:59 AM
western australia
1cuda Offline
1cuda  Offline
western australia
friend has a 70 440-6 cuda with a 22 inch radiator-yes fixed fan and spacer- can`t get a pic just yet-it`s on the other side of the country.
all the best
frank.
Re: E-body 22" radiator installation... [Re: 1cuda] #1256754
06/26/12 01:37 PM
06/26/12 01:37 PM
california
sbcjd Offline
sbcjd  Offline
california
I have a 1970 Challenger with a 440 4V engine with radiator 2998960 with a 216 fan and a 328 shroud with the factory clutch 070 and everything runs just fine. No clearance problems. Looking at your photos I wonder what shroud you are using and it appears the passengers side of the radiator has no shroud bracket. There should be fan shroud brackets on both sides of the 22 inch radiator. This makes me wonder if you are using the incorrect shroud. Just trying to help.
Re: E-body 22" radiator installation... [Re: sbcjd] #1256755
06/26/12 05:19 PM
06/26/12 05:19 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
This is the 22" setup in a 70 B-Body
This uses the "960" radiator w/328 shroud.
Shroud isn't on in these pictures.
Re: E-body 22" radiator installation... [Re: RJS] #1256756
06/26/12 05:20 PM
06/26/12 05:20 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
next
Re: E-body 22" radiator installation... [Re: sbcjd] #1256757
06/26/12 07:02 PM
06/26/12 07:02 PM
Houston, Tx
Houston, Tx
The fan's the problem... This is the fan that was on the car when my friend got it. Problem is the previous owner 26"'ed the car. Unfortunately, it is a cluster... So, I'm putting everything back to OEM. The 22" is just fine. My buddy just picked up a proper 2863224 7-blade 18" dia. fan & 2998328 shroud. The one in the picture is a 22" shroud with a 216 fan (not correct). Soooooooo, I only need to find a proper spacer now. That shouldn't be too hard...
Troy
Re: E-body 22" radiator installation... [Re: hemi68charger] #1256758
06/26/12 09:07 PM
06/26/12 09:07 PM
Anderson, IN
1969RR Offline
1969RR  Offline
Anderson, IN
Hey guy's, Don't mean to hi-jack, but I've got my original fan and spacer off my 70 Challenger RT that came with a 22" if you are interested. If I can help a fellow Mopar member, I'll give it to you. Send me a PM if I can help. Take care, Jeff
Re: E-body 22" radiator installation... [Re: 1969RR] #1256759
06/26/12 09:24 PM
06/26/12 09:24 PM
Houston, Tx
Houston, Tx
PM sent...
Troy
Re: E-body 22" radiator installation... [Re: hemi68charger] #1256760
06/26/12 09:36 PM
06/26/12 09:36 PM
Anderson, IN
1969RR Offline
1969RR  Offline
Anderson, IN
Back at ya! The fan and spacer I have is like the one RJS posted above. Jeff
Re: E-body 22" radiator installation... [Re: 1969RR] #1256761
07/05/12 09:14 PM
07/05/12 09:14 PM
Tenn.
jrwoodjoe Offline
jrwoodjoe  Offline
Tenn.
So, is there a factory style fan/clutch assembly that will work with the 22" radiator/shroud or do you HAVE to use the spacer and smaller fan? I have run into the same exact problem with the fan hitting the shroud but would like have a clutch assembly if possible.
Joe
65 Barracuda
70 Challenger
Re: E-body 22" radiator installation... [Re: jrwoodjoe] #1256762
07/06/12 12:35 AM
07/06/12 12:35 AM
PORT ALBERNI , BC., CANADA
superwrench Offline
superwrench  Offline
All I used in both '71's I have was the Mopar Viscous Fan Package...adequate cooling and fits like a glove.
Re: E-body 22" radiator installation... [Re: superwrench] #1256763
07/06/12 12:42 PM
07/06/12 12:42 PM
Tenn.
jrwoodjoe Offline
jrwoodjoe  Offline
Tenn.
Thanks for the advice. Searching the part number for my current fan blade, I see that it is 20", MP fan blade is 18 so that should do the trick. Thanks for the help. Joe.
65 Barracuda
70 Challenger
