Correct harmonic balancer #1256732
06/24/12 09:44 PM
06/24/12 09:44 PM
Ripley, NY
tcat446 Offline OP
tcat446  Offline OP
Ripley, NY
Is this the correct harmonic balancer for a 1973 318?
http://www.summitracing.com/parts/SUM-163273/
Re: Correct harmonic balancer [Re: tcat446] #1256733
06/24/12 10:05 PM
06/24/12 10:05 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
It says so in the description .
Re: Correct harmonic balancer [Re: JohnRR] #1256734
06/24/12 10:15 PM
06/24/12 10:15 PM
Ripley, NY
tcat446 Offline OP
tcat446  Offline OP
Ripley, NY
That's what I saw too. When I ordered it there was some confusion at summit over this item. So, this is for what kind of crank? Cast or forged they asked me. I told them it was for a 73 318 whatever that was.
Re: Correct harmonic balancer [Re: tcat446] #1256735
06/24/12 10:17 PM
06/24/12 10:17 PM
JohnRR Offline
JohnRR  Offline
It doesn't matter , as long as it's not for a 360 or a cast crank 340 all the smallblock balancers are the same for neutral balance, other than the pulley attaching bolt pattern.
Re: Correct harmonic balancer [Re: JohnRR] #1256736
06/24/12 10:20 PM
06/24/12 10:20 PM
Ripley, NY
tcat446 Offline OP
tcat446  Offline OP
Ripley, NY
Thank you JohnRR !!
