04 Durango Steering gear SLOP!! #1256637
06/24/12 07:19 PM
06/24/12 07:19 PM
Holly/MI
Dean_Kuzluzski Offline OP
Holly/MI
Got some slop in the steering gear of the wifes Durango. Has had it since it was on warranty but the dealer couldn't find it. Said it was "Swaybar links"
Is there an adjustment???
Or do I just R&R it?
Re: 04 Durango Steering gear SLOP!! [Re: Dean_Kuzluzski] #1256638
06/24/12 08:59 PM
06/24/12 08:59 PM
Ohio
Todd Offline
Todd  Offline
Ohio
What year Durango?
First thing to look at are the steering shaft u-joints from the column to the gear.
Re: 04 Durango Steering gear SLOP!! [Re: Todd] #1256639
06/24/12 09:10 PM
06/24/12 09:10 PM
Ohio
Todd Offline
Todd  Offline
Ohio
I'm sorry just now saw that its an 04.
The sway bar links won't give you alot of slop just extra body roll and some noise over uneven bumps.
BTW it has a steering rack and has no adjustment.
Re: 04 Durango Steering gear SLOP!! [Re: Todd] #1256640
06/25/12 05:34 AM
06/25/12 05:34 AM
Holly/MI
Holly/MI
Yeah, I knew that was a lame response when my wife past it on to me.
So no adjustment. Bummer, looks like it's all internal to the rack assembly then. I'll look into the cost of a replacement then. Wish I would have had time to push the dealer harder back when it was under warranty.
Thanks for the input.
Re: 04 Durango Steering gear SLOP!! [Re: Todd] #1256641
06/25/12 02:10 PM
06/25/12 02:10 PM
St. Charles, MO
wingman Offline
Uncreative Title
wingman  Offline
Uncreative Title
St. Charles, MO
What year Durango?
1969 Dodge Coronet Super Bee 383 A4
1970 Plymouth Road Runner 440 FC7 (sold)
Re: 04 Durango Steering gear SLOP!! [Re: wingman] #1256642
06/26/12 05:38 AM
06/26/12 05:38 AM
Holly/MI
Holly/MI
What year Durango?
Just checking on this thread.
I'll take a specific look at that. It could be it, that slop can be felt when shifting the tires fore & aft from either side when it is up off the ground. It makes sense.
Thanks guys!
Re: 04 Durango Steering gear SLOP!! [Re: Dean_Kuzluzski] #1256643
06/26/12 07:15 AM
06/26/12 07:15 AM
Ohio
Todd Offline
Todd  Offline
Ohio
What year Durango?
Are you sure that the inner and outer tie rods are OK? Have someone look at them when you do that.
Thanks guys!
Re: 04 Durango Steering gear SLOP!! [Re: Todd] #1256644
06/26/12 07:01 PM
06/26/12 07:01 PM
Holly/MI
Holly/MI
I looked at those pretty well and the slop was internal to the rack or at the column. It was pretty tight through the rack from left to right and right to left.
But I can check it again.
