71 Chal door panels...any advise? #1255952
06/23/12 12:40 PM
06/23/12 12:40 PM
Kent, WA
triple_green Offline OP
Kent, WA
I have the 71 challenger door panels from Year1/PALCO..that I bought 4 years ago. I know they have a bad reputation.
I tried to install them yesterday and it was just as promised. Did fit, holes don't line up etc.
Can anyone give any practical help to make them work. I am thinking about taking them to a professional upholstery guy in town.
Thanks!
Mark
68 Charger, 383 HP console auto, spring green, stock restoration
Re: 71 Chal door panels...any advise? [Re: triple_green] #1255953
06/23/12 12:46 PM
06/23/12 12:46 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
The pro guy is not a magician, don't expect him to be able do anything with them.
I'd look for OEM ones and paint them if neccassary.
Re: 71 Chal door panels...any advise? [Re: Challenger 1] #1255954
06/23/12 01:09 PM
06/23/12 01:09 PM
IN
ahy Offline
ahy  Offline
IN
I used a re-pop new set on a '70 I bought from Texas Acres. Probably the same or similar to the ones you have. A local upolstry shop installed them along with headliner, carpet and rear seat vinyl. They took a little work like re-enforcement of the hand rest mounts and I'm sure some tweaking of the holes. All in all they came out fine though.
Agree there is no magic but the upolstry guys got them to fit well without looking cobbled... better than I could have.
Re: 71 Chal door panels...any advise? [Re: triple_green] #1255955
06/23/12 04:16 PM
06/23/12 04:16 PM
NC
1970A66 Offline
1970A66  Offline
NC
If possible..............sell those Palco's and buy the new Metro door panels. They look and fit exactly like original. Not cheap at $1200 for front and rear but well worth it !!!
Re: 71 Chal door panels...any advise? [Re: 1970A66] #1255956
06/23/12 04:37 PM
06/23/12 04:37 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I saw Troy spend four hours EACH panel fitting Palco, Legendary, etc panels in his Challenger T/A to get as good as possible fit. Some of the metal structure hidden under the panel needed to be cut back. In the end that car was very rattle free.
Because the O.P. has stock rear panels I believe, the fitting fronts only should be a little easier.
The quality in fitment is going to be a result of the labor you put into them.
Re: 71 Chal door panels...any advise? [Re: autoxcuda] #1255957
06/23/12 04:39 PM
06/23/12 04:39 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Step one: Locate a Dumpster with a large enough opening to accept the Palco panels
Step two: Deposit them and start over with originals or Metro reproductions.
Re: 71 Chal door panels...any advise? [Re: ScottSmith_Harms] #1255958
06/26/12 12:21 AM
06/26/12 12:21 AM
Kent, WA
Kent, WA
I've got the original black ones from the car should I just dye them?
Re: 71 Chal door panels...any advise? [Re: triple_green] #1255959
06/26/12 10:23 AM
06/26/12 10:23 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
I painted my A-pillars and kick panels with SEM Adhesion Promotor and Landau Black. They really look nice. They don't look like they have been painted. It just looks like new plastic.
Make sure to clean the panels before spraying any paint. When you think you have them clean enough...clean them a few more times.
Re: 71 Chal door panels...any advise? [Re: triple_green] #1255960
06/26/12 10:26 AM
06/26/12 10:26 AM
Cincinnati, Ohio
Cincinnati, Ohio
Yes, just like Burdar did.
Re: 71 Chal door panels...any advise? [Re: triple_green] #1255961
06/26/12 12:11 PM
06/26/12 12:11 PM
Alabama USA
Silver6Pak Offline
Silver6Pak  Offline
Alabama USA
That might be the ticket, it's what I had done to mine. Nothing was wrong with the structure, they were just faded. The upholstery dude had a hot-dye machine that really soaked the color back into them.
Re: 71 Chal door panels...any advise? [Re: Silver6Pak] #1255962
06/28/12 11:50 AM
06/28/12 11:50 AM
Kent, WA
Kent, WA
bump
