Page 3 of 4 1 2 3 4
Re: Grill Repair. GREAT SCOTT (Smith)! IT REALLY WORKS!!! [Re: steve70] #1255419
10/04/12 08:55 PM
10/04/12 08:55 PM
Fort Lauderdale
Dave440 Offline
Dave440  Offline
Fort Lauderdale
Good tips...thanks!
I thought I had an unused tube of something. Just found 2 things I'd already bought. Got Quicksteel plastic putty which i've used before and is good stuff....but I'm not sure it'll work on the timing cover.
Also have an unused tube of Permatex Perma Poxy 2 part 5min plastic weld. Primary ingredients are Methyl Methacrylate and Methacrylic acid.
Says good for ABS Acrylic Fiberglass Glass PVC Styrene Steel Vinyl Wood. Looks like it'll work unless the cover is made of polyethylene or polypropylene.
Re: Grill Repair. GREAT SCOTT (Smith)! IT REALLY WORKS!!! [Re: Dave440] #1255420
10/08/12 11:38 PM
10/08/12 11:38 PM
canaan ct usa
moparclown Offline
moparclown  Offline
canaan ct usa
I have used the process of acetone and shavings to repair grilles in the past but have switched to a product made by devcon called plastic welder.It comes in a two part syringe and bonds very nice to the plastic grilles.I just started to repair two 72-74 cuda grilles and a 70 dart grille.I can get some pics of the repairs if anyone would like to see?
Re: Grill Repair. GREAT SCOTT (Smith)! IT REALLY WORKS!!! [Re: moparclown] #1255421
10/09/12 12:44 AM
10/09/12 12:44 AM
Seattle, WA
rss Offline
rss  Offline
Seattle, WA
Post'em up
Re: Grill Repair. GREAT SCOTT (Smith)! IT REALLY WORKS!!! [Re: rss] #1255422
10/09/12 04:19 AM
10/09/12 04:19 AM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
Why not use ABS shaving instead of PVC shavings?
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: Grill Repair. GREAT SCOTT (Smith)! IT REALLY WORKS!!! [Re: rss] #1255423
10/09/12 09:29 PM
10/09/12 09:29 PM
canaan ct usa
moparclown Offline
moparclown  Offline
canaan ct usa
Post'em up
OK then
I got the grilles on Sunday and the silver one was broken in half as was the blue cuda grille.I will try and post pics as I go forward with this grille as I need to repair both front corner pieces with some pieces from some parts grilles.
Re: Grill Repair. GREAT SCOTT (Smith)! IT REALLY WORKS!!! [Re: moparclown] #1255424
10/09/12 09:32 PM
10/09/12 09:32 PM
canaan ct usa
moparclown Offline
moparclown  Offline
canaan ct usa
another pic
Re: Grill Repair. GREAT SCOTT (Smith)! IT REALLY WORKS!!! [Re: moparclown] #1255425
10/09/12 09:36 PM
10/09/12 09:36 PM
canaan ct usa
moparclown Offline
moparclown  Offline
canaan ct usa
A pic of a 69 formuls S grille that was in 4 pieces that I repaired.
Re: Grill Repair. GREAT SCOTT (Smith)! IT REALLY WORKS!!! [Re: moparclown] #1255426
10/10/12 08:29 PM
10/10/12 08:29 PM
canaan ct usa
moparclown Offline
moparclown  Offline
canaan ct usa
Got out of work early due to rain and did some work on the grille today.Cleaned up the lower area that was missing the section and made a mold out of masking tape and filled that.
Re: Grill Repair. GREAT SCOTT (Smith)! IT REALLY WORKS!!! [Re: moparclown] #1255427
10/10/12 08:33 PM
10/10/12 08:33 PM
canaan ct usa
moparclown Offline
moparclown  Offline
canaan ct usa
pic of the repair and now its starting to get some structure
Re: Grill Repair. GREAT SCOTT (Smith)! IT REALLY WORKS!!! [Re: moparclown] #1255428
10/11/12 04:23 PM
10/11/12 04:23 PM
missouri, USA
moparmojo Offline
moparmojo  Offline
missouri, USA
Man, looking good. Keep up the good work and keep those pics coming. I love threads like this!
Re: Grill Repair. GREAT SCOTT (Smith)! IT REALLY WORKS!!! [Re: moparmojo] #1255429
10/12/12 10:11 PM
10/12/12 10:11 PM
Toronto, Ontario, Canada
johndart Offline
johndart  Offline
This is great, I am looking forward to your repairs on the 70 Dart
grill so I have some reference for mine. But once repairs are done the next big question will be how to paint the silver & black on the grill.
Re: Grill Repair. GREAT SCOTT (Smith)! IT REALLY WORKS!!! [Re: johndart] #1255430
10/12/12 10:45 PM
10/12/12 10:45 PM
canaan ct usa
moparclown Offline
moparclown  Offline
canaan ct usa
The blue grille
Re: Grill Repair. GREAT SCOTT (Smith)! IT REALLY WORKS!!! [Re: moparclown] #1255431
10/12/12 10:46 PM
10/12/12 10:46 PM
canaan ct usa
moparclown Offline
moparclown  Offline
canaan ct usa
grafting in pieces from some parts grilles
Re: Grill Repair. GREAT SCOTT (Smith)! IT REALLY WORKS!!! [Re: moparclown] #1255432
10/12/12 10:49 PM
10/12/12 10:49 PM
canaan ct usa
moparclown Offline
moparclown  Offline
canaan ct usa
set in place but still need plenty of finish work
Re: Grill Repair. GREAT SCOTT (Smith)! IT REALLY WORKS!!! [Re: moparclown] #1255433
10/13/12 08:43 AM
10/13/12 08:43 AM
Virginia
larry4406 Offline
larry4406  Offline
Virginia
Moparclown - what are you doing to ensure that the "angle" between the rejoined pieces matches the original so that it follows the header panel and bumper?
I need to piece mine back together as well.
Re: Grill Repair. GREAT SCOTT (Smith)! IT REALLY WORKS!!! [Re: larry4406] #1255434
10/13/12 12:00 PM
10/13/12 12:00 PM
canaan ct usa
moparclown Offline
moparclown  Offline
canaan ct usa
I have a header panel from a 71 up cuda and I have a nice straight bumper filler panel from a 73 cuda use as reference
Re: Grill Repair. GREAT SCOTT (Smith)! IT REALLY WORKS!!! [Re: moparclown] #1255435
10/13/12 01:09 PM
10/13/12 01:09 PM
Lost in the 70's
440gtx6 Offline
440gtx6  Offline
Lost in the 70's
Never heard of using body filler for this job but here's a link to another method using it. No idea if it works.
http://www.automedia.com/Plastic_Grille_Repair/res20011101gp/1
69 EF8 GTX 440 auto
72 EB5 RR/GTX 440 auto
70 EW1 GTX 440-6 4 spd
70 EF8 Satellite 318 auto (452 coming soon)
70 FK5 Satellite 318 auto
71 FC7 Cuda 340 4 spd
Re: Grill Repair. GREAT SCOTT (Smith)! IT REALLY WORKS!!! [Re: 440gtx6] #1255436
10/13/12 01:13 PM
10/13/12 01:13 PM
Lost in the 70's
440gtx6 Offline
440gtx6  Offline
Lost in the 70's
69 EF8 GTX 440 auto
Re: Grill Repair. GREAT SCOTT (Smith)! IT REALLY WORKS!!! [Re: 440gtx6] #1255437
10/13/12 01:16 PM
10/13/12 01:16 PM
Lost in the 70's
440gtx6 Offline
440gtx6  Offline
Lost in the 70's
And another with bondo and fiberglass. Not advocating any of these, just throwing them out there. There are some pictures.
http://www.dodgecharger.com/forum/index.php/topic,30425.0.html
69 EF8 GTX 440 auto
Re: Grill Repair. GREAT SCOTT (Smith)! IT REALLY WORKS!!! [Re: 440gtx6] #1255438
10/13/12 01:19 PM
10/13/12 01:19 PM
Lost in the 70's
440gtx6 Offline
440gtx6  Offline
Lost in the 70's
One more on the kit, this time with a video.
http://www.youtube.com/watch?v=5yfCzBX409s
69 EF8 GTX 440 auto
Page 3 of 4 1 2 3 4
