Grill Repair. GREAT SCOTT (Smith)! IT REALLY WORKS!!!
#1255379
06/22/12 01:45 AM
06/22/12 01:45 AM
Posts: 10,938 Spokane Valley, WA
Big Bad Bee
Spokane Valley, WA
About a year ago, there was a post about how to mend an ABS plastic grill. My neighbor Scott Smith provided a solution and remembering best I could, I replicated the process yesterday on my 1970 Superbee grill, which had complete cracks all along the bottom row of vertical ribs. So what follows is a step by step description of what I did. This is an example of what I started out with. 3/4 of the ribs on the lower side of the grill cracked in half. First I washed them with water and dish washing liquid, then sanded the paint off broken areas to insure a good bond. Definitely the slowest, most tedious part of the project. Next, grabbing a stick of 2.5" diameter ABS plumbing pipe I bought at the Home Depot and my leatherman tool, I spent about 45 minutes scraping off shavings. I did some like little wood chips and others very fine shreads by running the blade edge perpendicular to the surface of the pipe. The fine shreads worked really great, the worked chips ok, but they took longer to melt. I poured a couple tablespoons of acetone into a glass jar and began mixing in the ABS shavings with a piece of all-thread. The shavings melt super fast. I made it a about the runny consistancy of salad dressing. Note two things here. I took some clothes pins and took the spring out, turned the wood sides backwards and inside out, put the spring back on. Now I had little wooden needle nose clamps. I shaved some down to fit in slots that were tight, sometimes cutting one tip shorter than the other. Then starting on one end and working my way across, I applied the goo to 3 or 4 breaks and then applied a clamp. I applied the goo with a Starbucks coffee lid stopper. they are made of soft rubberized plastic and the acetone doesn't melt them. They have a nice flat paddle end on them to hold and a broad tip, unlike a toothpick. Toward the end, it got a little tricky but working quickly, I got all the joints glued and placed the last two clamps. I used 6 in all. The ABS goo skins pretty fast and I had to add a little acetone and stir it up about 2/3 of the way through the process on each grill. Once I got the whole thing glued and clamped, I went over each spot building up the surrounding area of each break. I finished both grills and let them set over night. The results... Lest you think I am a crazy man (you may be right. I may be crazy...), I did test it out on a grill piece before I attempted the whole deal. The acetone takes a few days to cure really hard and it's very strong. Next I will file away the blobs with a fine, flat rattail file, sand and spray with SEM black. Thanks for your suggestion on this, Scott! It works great.
I’m listening.
Re: Grill Repair. GREAT SCOTT (Smith)! IT REALLY WORKS!!!
[Re: dogdays]
#1255386
06/22/12 01:32 PM
06/22/12 01:32 PM
Posts: 2,536 o
wunderless
o
Awesome stuff!
I plan on pulling out my cuda grille this winter and doing it. I suppose this technique would work for that.
Thank you!
But existing is basically all I do.
[Re: dogdays]
#1255388
06/22/12 02:16 PM
06/22/12 02:16 PM
Big Bad Bee
Spokane Valley, WA
Congratulations, it worked for you. Probably as strong as original. This was the subject of an article in Mopar Muscle a few years back, thanks for the reminder.
Do you think you could manufacture small parts with, say, a plaster of paris mold and possibly adding a bit more solvent to your goo? I'm curious.
R.
Hmmmmmmm. Interesting idea. I think so. As far as I can tell, the ABS hardens just as good as the original product once the acetone is gone, which takes a while. I left a good amount in the jar from the first go round just to see what it would do, and because I knew that it would be easier to get out in one big chunk. It hardened to a shiny, hard consistancy just like a plumbing fitting (elbow, coupling etc.). If I knew anything about plaster molds I would probably give it a shot. The limiting factor probably being how big the part is. It would take a lot of shaving and mixing to get an 8 ounce cup going and I don't think you would want to risk filling the mold in more than just one batch.
Scott might be able to address it. He used to work in the injection molded plastic industry. Scott?
I’m listening.
[Re: Big Bad Bee]
#1255389
06/22/12 05:19 PM
06/22/12 05:19 PM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
Awesome stuff!
Thank you!
Yes it works on Cuda grilles as well as most other muscle car era plastic Mopar grilles.
ABS thermoplastic resin is not engineered to be chemically broken down and reused/reconstituted, it is meant to be heated and molded under pressure (hence the term "thermo" plastic) and even when reheated it will lose a percentage of it's original properties each time. It WILL also lose some of it's original characteristics when melted chemically and allowed to harden, but the changes are subtle enough that it works quite well as a repair material. In some cases you could make small molded parts as suggested (I'd use a silicone mold as opposed to plaster) but the outcome and durability will be variable.
[Re: ScottSmith_Harms]
#1255390
06/22/12 06:08 PM
06/22/12 06:08 PM
Big Bad Bee
Spokane Valley, WA
Good explanation. I was concerned about chemical breakdown, especially after repeated applications of the acetone.
I was curious to note that the acetone smells like PVC and ABS plastic cement. When I worked in plumbing I was told that the cement actually melts and creates a chemical bond between two parts. I'm guessing that the light amount of acetone in the "Goo" I made is not only acting on the melted ABS but also on the surface of the grill parts.
I’m listening.
[Re: Sinitro]
#1255393
06/22/12 09:50 PM
06/22/12 09:50 PM
Big Bad Bee
Spokane Valley, WA
Ice, please do!
Sinitro, You need a road trip to San Berdoo!
I’m listening.
[Re: DARTH V8Я]
#1255394
06/22/12 11:49 PM
06/22/12 11:49 PM
Posts: 3,031 Erda, UT
67Charger
Erda, UT
Awesome work! If you don't mind, I'll post later a very simple effective way to fix a grill with pieces missing. End results are a repair that's stronger then the surrounding area
I'm looking forward to it. I've got 3 '68 Charger grilles that all need some work like this.
11.33 @ 118.46 on motor 10.75 @ 125.35 w/ a little spray Now, high Speed Open Road Racing - Silver State Classic Challenge, Nevada Open Road Challenge, Big Bend Open Road Race Rocky Mountain Race Week 2020, 2022 2.0, Sick Week 2023
[Re: Big Bad Bee]
#1255395
06/22/12 11:50 PM
06/22/12 11:50 PM
Posts: 2,154 Its a TRAP!
DARTH V8Я
Oh No!! I just had a moron attack!
Its a TRAP!
Ice, please do!
I should have taken more pics.. but its on a Chevy Vega lol. Anyways I was frustrated with trying to make plastic 'shelves' for grills that I have that were broken.. a real PITA to shape, bond, etc. I'm into make model RC WWII aircraft bigtime, and familular with balsa wood. When finished properly, it harder the thermo/abs plastic, and the balsa has the added bonus of easly shaped to conform to whatever I need.
Thats what I did. Shaped fit a piece of balsa wood, then covered with resine ( that kind one uses with fiberglass mat). I then used a sponge brush to spread out the resine. Its almost self leveling, after it dries theres very minimal sanding to do, and one ends up with a very strong repair that after painted, looks 100% factory.
Pic below dosn't do it justice, but there it is in a nutshell so to speak.
So theres my little contribution to the MoPar community
When it takes more than a sweet mullet to prove you rule at the trailer park..
