572 hemi how much hp n tq #1255373
06/22/12 01:18 AM
06/22/12 01:18 AM
Maryville TN
68528hemi Offline OP
Maryville TN
4.5 bore and stroke ross 10.1 pistons 7.100 rods. heads are new iron heads that have been opened up. Solid roller cam 254 265 at 50 633 lift. roller rockers two 750 aed carburators on a opened up new cross ram intake msd 6al msd pro billet distributor and 10.4 mm wires I'm hopeing for 700 to 800 hp n tq what do you all think.
Re: 572 hemi how much hp n tq [Re: 68528hemi] #1255374
06/22/12 12:31 PM
06/22/12 12:31 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
I hope you achieve your goals but 800 seems like a lot to ask from a pump gas crossram. I would expect 800 with max compression and a mod man intake. Good luck.
2011 Drag Pak Challenger
Re: 572 hemi how much hp n tq [Re: rickseeman] #1255375
06/22/12 01:22 PM
06/22/12 01:22 PM
Virginia Beach, VA
O
Old School Offline
Old School  Offline
O
Virginia Beach, VA
not enough cam or compression for 800 hp. torque around 725-750.
68 cuda formula S 588" bb 5sp
70 CUDA CONVERT 500" 5SP (SUBLIME)
70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
Re: 572 hemi how much hp n tq [Re: Old School] #1255376
06/22/12 01:34 PM
06/22/12 01:34 PM
Sunnyvale, CA
Jeepmon Offline
Jeepmon  Offline
Sunnyvale, CA
I'm not sure what the numbers will be.. but it'll be a beast on the streets.. good luck with your build
Re: 572 hemi how much hp n tq [Re: Jeepmon] #1255377
06/22/12 08:17 PM
06/22/12 08:17 PM
Kansas City Metro
mbogina Offline
mbogina  Offline
Kansas City Metro
Probably more dependent on the head flow than anything. The last 572 MP Crossram Hemi I did had pretty mild aluminum heads that flowed 404 CFM at 28", a bit over 12:1 comp and a more aggressive cam, but it also made 915+ HP and 800+ TQ. Of course, an alum head 12:1 motor is closer to the equivalent of a 11:1 Cast iron head motor, so you are giving up some HP/TQ in both compression and cam.
Be a Rebel- Break the Laws of Physics!
Re: 572 hemi how much hp n tq [Re: mbogina] #1255378
06/29/12 01:21 AM
06/29/12 01:21 AM
Deep DEEP SOUTH
LAD 524 Offline
LAD 524  Offline
Deep DEEP SOUTH
Just finished up a 572:
Hemi mega block 4.5" bore
4.5" Bryant crank
Saenz rods
11:1 CR, Diamond pistons - coated tops/skirts
Sealed Power rings
ARP rod, crank, head studs, oil pan studs, flywheel bolts
Bullet roller 752/684" lift 270/280 @ .050" 112 & Isky EZ roller lifters
Indy Legend heads ported 420 cfm
Stage V rollers
MSD dist/box/crank trigger
Indy raised port SP intake
Pro systems1150
Billet electric water pump
Milodon ext dual line swinging pickup and pump
850HP at 6500
770TQ at 5200
