Change the primary jet up one size, remember that the original Carter jets where in .003 increment on the diameter. IE a 16-391 is .091 diameter, the 16-395 are .095 diameter
![](/ubbthreads/images/graemlins/1343795-scratchchin.gif)
One other thing is on the original Carter jets with the three step rods they had a raised up shoulder on the primary jets, not flat like the two step and secondary jets are
![](/ubbthreads/images/graemlins/shruggy.gif)
One other solution is to reduce the diameter of the intermediate step on the rods, I know racers who use to watch TV while using a piece of very fine sandpaper to tune up the meterting rods to meet there needs
![](/ubbthreads/images/graemlins/scope.gif)
Use a good set of dial calipers or a good micrometer to get it right
![](/ubbthreads/images/graemlins/Twocents.gif)
Sand a little, measure a lot
![](/ubbthreads/images/graemlins/thumbs.gif)
