572 hemi how much hp n tq #1255159
06/21/12 06:30 PM
06/21/12 06:30 PM
Maryville TN
68528hemi Offline OP
Maryville TN
4.5 bore and stroke ross 10.1 pistons 7.100 rods. heads are new iron heads that have been opened up. Solid roller cam 254 265 at 50 633 lift. roller rockers two 750 aed carburators on a opened up new cross ram intake msd 6al msd pro billet distributor and 10.4 mm wires I'm hopeing for 700 to 800 hp n tq what do you all think.
Re: 572 hemi how much hp n tq [Re: 68528hemi] #1255160
06/21/12 08:05 PM
06/21/12 08:05 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
That should get you there. Assuming it's tuned right.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: 572 hemi how much hp n tq [Re: 68528hemi] #1255161
06/21/12 08:08 PM
06/21/12 08:08 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Who did your work, I'm in Morristown and have questions
Re: 572 hemi how much hp n tq [Re: 68528hemi] #1255162
06/22/12 12:56 AM
06/22/12 12:56 AM
Maryville tn
67coronetman Offline
Maryville tn
I am sure that HP & TQ goals will be well within reach.!
Old car are me......
Re: 572 hemi how much hp n tq [Re: 67coronetman] #1255163
06/22/12 03:13 AM
06/22/12 03:13 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
I have a similar combination, 9.5-1, crane roller with 248@.050 with .620 lift, stageV heads that flow 367@600, stageV intake with shear plates and quick fuel carbs, I am expecting around 700HP and torque. What do your heads flow? Tim
Re: 572 hemi how much hp n tq [Re: astjp2] #1255164
06/22/12 01:33 PM
06/22/12 01:33 PM
Central ND
440custom Offline
440custom  Offline
Central ND
Mine is somewhat similiar only it has a mild hyd roller cam. Peak hp 745 @ 6000 rpm, peak Torque 710 @ 4800 rpm. Supposedly, if I feel this isn't enough, a quick cam change and 1000 hp is easily attainable.
This is supposed to be real streetable, just haven't bolted it into the car yet.
Re: 572 hemi how much hp n tq [Re: 440custom] #1255165
06/22/12 04:14 PM
06/22/12 04:14 PM
North Carolina, USA
Silverbullet2 Offline
North Carolina, USA
I don't think 700/800 is too much to ask at all. Be interesting to see what that motor would do with a set of those Canfield/Indy heads. Rumor has it 100 CFM better than Stage Vs.
Re: 572 hemi how much hp n tq [Re: 68528hemi] #1255166
06/23/12 10:08 PM
06/23/12 10:08 PM
Maryville tn
Maryville tn
Hey let us know how that big hemi does when you get it all done and Dynoed i bet it will do killer.!
