Page 3 of 4 1 2 3 4
Re: Anyone Use Extrude Hone for Exhaust Manifolds? [Re: dOoC] #125467
10/01/08 02:14 PM
10/01/08 02:14 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
I can get them done for $595.00 plus shipping if anyone wants some done (that's my cost, no mark up).
Re: Anyone Use Extrude Hone for Exhaust Manifolds? [Re: ScottSmith_Harms] #125468
10/01/08 02:20 PM
10/01/08 02:20 PM
Ansonia, CT
CJK440 Offline
CJK440  Offline
Ansonia, CT
71
72
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
Re: Anyone Use Extrude Hone for Exhaust Manifolds? [Re: CJK440] #125469
10/01/08 02:38 PM
10/01/08 02:38 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
BTW, I removed the heat riser assemblies from both manifolds, dyno test wil be done with a single long bolt through both of them to fill the holes.
Re: Anyone Use Extrude Hone for Exhaust Manifolds? [Re: ScottSmith_Harms] #125470
10/01/08 03:22 PM
10/01/08 03:22 PM
Florida STAYcation
dOoC Online penguin-006
The village idiot's idiot
dOoC  Online Penguin-006
Florida STAYcation
Even at 6 hun ... that is an awful lot of $$$ to just push some abrasive and clay through cast iron.
Re: Anyone Use Extrude Hone for Exhaust Manifolds? [Re: dOoC] #125471
10/01/08 03:33 PM
10/01/08 03:33 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Almost 7 hun for a set from EH ? .... it used to be under 4 hun !!
I say PAY yourself almost a HUN per hour and do-it yourself. I spent about 6 or so hours on a set of 69 HP B engine ones and were more than pleased with the results.
You can do the extrude hone process oh proctologist of fibberglASS ???
please elaborate
Re: Anyone Use Extrude Hone for Exhaust Manifolds? [Re: CJK440] #125472
10/01/08 03:35 PM
10/01/08 03:35 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Chris the rib on the 72 is to hold the heat stove for the air cleaner, in case you didn't know that
Re: Anyone Use Extrude Hone for Exhaust Manifolds? [Re: JohnRR] #125473
10/11/08 04:46 PM
10/11/08 04:46 PM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
It seems to me that you could accomplish the same as Extrude Hone with a wet sand blasting set up.
I can't remember the name now,
but I am pretty sure I had a small electric pressure washer (German ?) in the 1980s that came stock with a nozzle that would suck in sand and blast it out with the high pressure water.
a quick Google search found this:
http://www.pressureparts.com/None-C-SandBlas-Pressure-Part-391510.aspx
I admit that it would be hard to get even an extra long shank carbide burr inside some of the exhaust manifold passages but the wet sand blast nozzle should work
Re: Anyone Use Extrude Hone for Exhaust Manifolds? [Re: JohnRR] #125474
10/12/08 02:10 AM
10/12/08 02:10 AM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
please elaborate
Well here we go again folks! Walk over to the window and look out.
FULL MOON ON TUESDAY!
FEEL THE LOVE
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: Anyone Use Extrude Hone for Exhaust Manifolds? [Re: Rug_Trucker] #125475
10/12/08 08:51 AM
10/12/08 08:51 AM
Wilmington,NC
I
I go fast Offline
I go fast  Offline
I
Wilmington,NC
If you blow enough hot air through them you can accomplish the same results.
Re: Anyone Use Extrude Hone for Exhaust Manifolds? [Re: I go fast] #125476
11/13/08 11:37 AM
11/13/08 11:37 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Ok,
This just in.......
Had my 340 dyno'd this week, I don't have the dyno sheets yet but I do have a report on Extrude Honed Manifolds VS stock manifolds. With ZERO changes other than removing the EH manifolds and replacing with stock unmodified originals (both sets were nice originals of 1971 A-body 340 manifolds, one set EH, the other stone stock, bead blasted clean, no repairs, heat risers removed and blocked off).
A grand total of 4-5 HP difference basically accross the board. Pretty much what I expected.
Additional notation, removing the stock air cleaner netted an additional 8-9 HP gain using either set of manifolds.
This was on a 426 Cube stroked 340 running a hydraulic cam and pump gas friendly 9.7:1 compression, VERY stock 71 TQ carb, intake, etc. (FAST style build 340 but compromised big time by hyd cam choice and lower compression for streetability).
Re: Anyone Use Extrude Hone for Exhaust Manifolds? [Re: ScottSmith_Harms] #125477
11/13/08 12:22 PM
11/13/08 12:22 PM
USA
3
360view Offline
360view  Offline
3
USA
thanks for posting that rear wheel dyno result
is the 5 hp gain
with the Extrude Hone exhaust manifolds
about 1.5% or so
of the maximum horsepower?
Re: Anyone Use Extrude Hone for Exhaust Manifolds? [Re: ScottSmith_Harms] #125478
11/13/08 12:22 PM
11/13/08 12:22 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
Thanks for the update Scott, I was waiting for it!
Can you say where that motor is power wise? Obviously the manifolds would make even less difference on a smaller cubed motor. Sounds like it's not worth it except for the very few looking for every last hp and constrained to use stock manifolds.
Cheers,
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: Anyone Use Extrude Hone for Exhaust Manifolds? [Re: ScottSmith_Harms] #125479
11/13/08 12:26 PM
11/13/08 12:26 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Scott , thanks , question , what were you using for an air filter element ? Also did they just pull off the top of the air cleaner or remove it completely ?
Re: Anyone Use Extrude Hone for Exhaust Manifolds? [Re: 360view] #125480
11/13/08 12:32 PM
11/13/08 12:32 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
is the 5 hp gain
about 1.5% or so
Didn't sound like a rear wheel dyno. Could you clarify, Scott?
Because the motor is built out to 426 cubes I wonder if the 1.5% might not be applicable to a smaller cube motor with less HP.
Would it be applicable to a smaller cube motor with the same HP? That motor would have to a combination of more heads, cam, etc to acheive the same HP I assume.
Re: Anyone Use Extrude Hone for Exhaust Manifolds? [Re: DPelletier] #125481
11/13/08 12:35 PM
11/13/08 12:35 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
The dyno test was run on an engine dyno (not a Chassis dyno). I wanted the engine to be dyno'd with most accessories installed to best simulate what it would really be once installed in the car, stock air cleaner, pullies, ex manifolds etc.
Unfortunately the dyno shop only had headers available for a small block and due to this his exhaust hook ups were only for headers. Of course this didn't come up until 2 days before the run so I had to go out and have a muffler shop cobble up some ex mnfld collector adapters and short ex pipes which ended up reducing the 2.00 ex mnfld outlets to 1.75 diam tubing (pretty serious cork).
At any rate, the engine HP peaked at 439hp at just under 5,900 RPM (hyd cam or intake manifold volume being too small likely factors there) and 480 somthing ft lbs or torque.
Nothing earth shattering but a solid showing considering the build combo and the restrictive exhaust pipes. I'm thinking with some minor tuning and a good exhaust setup 450HP plus should be a no brainer once in the car. If I ever decide to go with a roller cam even more HP could be available, I built the short block to take anything I can throw at it in the future so there's a gob of room for improvments down the road.
As far as Extrude Honing and the difference it makes. I think there is a limit to gains you can expect but IMO every engine will benifit differently from it. As I've said before, you chase the bottle necks in the combo, if the bottleneck is the manifolds it will make a bigger difference and push the bottle neck to some other area needing improvment to gain more HP.
Re: Anyone Use Extrude Hone for Exhaust Manifolds? [Re: autoxcuda] #125482
11/13/08 12:38 PM
11/13/08 12:38 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
John I can't answer the AC questions yet but I'll ask, I believe it was removed completely, I also believe it was a stock filter.
Re: Anyone Use Extrude Hone for Exhaust Manifolds? [Re: ScottSmith_Harms] #125483
11/13/08 12:41 PM
11/13/08 12:41 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
should have tried it with a K+N , they are allowed in F.A.S.T.
Re: Anyone Use Extrude Hone for Exhaust Manifolds? [Re: JohnRR] #125484
11/13/08 01:06 PM
11/13/08 01:06 PM
NORTHERN VA
THESHAKERPROJECT Offline
NORTHERN VA
Hey Scott, can you post the sheet...and what happened to the "15 to 20 hp" ??? You could easily loose or gain 5hp with the choice of muffler you run and on a real 340 CI motor the gains would probally be less than 5hp. I remember when Dulcich dynoed a 440 and gained 2-3 ftlb of tq with the extrude honed BB set...not really worth the effort and expence AND I hear that some exhause manifolds will crack over time. I would like to have seen that 426 run with a nice set of TTI headers as well as the manifolds.
Re: Anyone Use Extrude Hone for Exhaust Manifolds? [Re: THESHAKERPROJECT] #125485
11/13/08 01:27 PM
11/13/08 01:27 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Keep in mind that If I were building a race or bracket engine this would have been an entirely different build.
My goals were a bit complicated but along the lines of a STOCK appearing ( all correct externals for 1971, carb, intake, exhaust, air cleaner, etc.) PUMP GAS (lower compression for safe no detonation street duty engine that would require MINIMAL maintainance (hydraulic cam, no removing valve covers, etc.). There's an outside chance that I could someday run it in a FAST event and I wanted it to be a viable canidate for that as well.
Due to all of the above I didn't run header tests, roller or solid cams, better carb or intake, high compression, etc. Of course in electing to side step all of those I walked away from a couple hundred HP as well, something I can always add or change later if I choose to do so even if I left the compression alone.
The bottome line is that if you want every available HP available to whatever combo you need to make choices with nearly every aspect of the combo, not just one item. Extrude honing is a viable choice but can result in a minimal gain for the money spent, it's not for everyone. As far as cracking due to EH them, I doubt it, you can't even see dimensional changes in the manifolds, they simply look polished inside, I doubt there is any appreciable thinning that could lead to cracking, in fact the deburring action of polishing them probably decreases the likelyhood.
This old saying comes to mind "Speed costs money son, how fast do you want to go?"
Re: Anyone Use Extrude Hone for Exhaust Manifolds? [Re: THESHAKERPROJECT] #125486
11/13/08 03:29 PM
11/13/08 03:29 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Extrude Hone CLAIMED 15-20 , Scott was alot closer with his 5-10 guess
Why am I not surprised to see the unrealistic claims from someone taking your hard earned cash?
Reminds me of someone else
Page 3 of 4 1 2 3 4
