88 Dakota rack and pinion questions! #1254021
06/19/12 10:28 PM
06/19/12 10:28 PM
Illinois USA
justnuts40 Offline OP
Illinois USA
I used a 88 Dakota front in in my 37 truck street rod. Can't seem to get my power steering to do anything. It has a new rack, the pump worked in the doner truck? The lines were un hooked a long time. Could I have hooked them back up to the wrong holes on the rack? Now I have the pressure line hooked to the top hole on the rack and the return to the bottom hole. Need some help!
Thanks, Tony
etony58@gmail.com
Re: 88 Dakota rack and pinion questions! [Re: justnuts40] #1254022
06/20/12 11:18 AM
06/20/12 11:18 AM
It's a dry heat
gtx6970 Online content
gtx6970  Online Content
It's a dry heat
I don't think it's possible to reverse them due to flare nut size
