Re: Challenger Back Window
[Re: Roadrunner440-6]
#125378
09/24/08 11:32 AM
09/24/08 11:32 AM
Posts: 1,675 Mi.
G-Money1320
Mi.
Its called butyl and you put it on the glass then set the window in and your done.
416 stroker from Nick at Compu-flow. 11.14 in full street trim. Seems like a new best every time out. 11.06 open headers----so far!!
[Re: 1_WILD_RT]
#125384
09/25/08 12:52 PM
09/25/08 12:52 PM
Challenger 1
Cincinnati, Ohio
US automakers didn't start using the glass as a stressed part of the body till the eighties
Makes sence, he did a good sales job on me. But he was a big GTO restorer so we connected pretty good. He thought I was only a diesel truck mechanic and could'nt beleive it when he saw my home garage.
[Re: IMGTX]
#125386
09/25/08 02:03 PM
09/25/08 02:03 PM
Challenger 1
Cincinnati, Ohio
I have been doing my own windows since I was 13. they are pretty easy to do. Best in the summer, cold glass cracks easier. Take your tme and if it doesn't set right the frist time cut it out and do it again. Don't try to push it out and reset it. DAMHIK
Like he said the older cars do not need the urethane sealer to bond the glass to the cars since they are not structural components.
It is my understanding that while Urethane is strong it is not UV resistant. since it isn't new cars have black edges to protect the selaer from degrading in sunlight. If that is true then Butyl tape is better on old cars since they do not have the black edges.
Gary you do great work you do on your cars. so if your window guy did a good job he must have done a real good job but he was a salesman. You can install the older windshields without the primer and they will be fine but may leak faster if the windshieild doesn't fully adhear to the body. Also the primer is not a "Tradesman only" item, several companies make it including 3M. Most glass shops have big bottles they will loan you if you ask. It used to be there was a different primer for the glass and the metal of the body now most companies sell one for both.
Very good info, Thanks for sharing.
