Help! Wheel Studs #1253535
06/19/12 02:16 AM
06/19/12 02:16 AM
Rochester NY
Jer Offline OP
Jer  Offline OP
Rochester NY
I'm replacing the wheel studs on the front hubs of my '68 Coronet R/T. I need 3" studs, the hubs have holes of 0.630, and the factory knurls measure 0.650. I can find Dorman stock replacements, but no 3" studs. Summit, Mancini, Jegs, Rock Auto.... nothing. Any suggestions for who might have these? Thanks, guys! Jer
Re: Help! Wheel Studs [Re: Jer] #1253536
06/19/12 08:43 AM
06/19/12 08:43 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
I've found that sometimes when going to longer studs, you may have to drill the holes in the hub bigger to accept a more common knurl size
**Photobucket sucks**
