think i found my miss #1253280
06/18/12 07:19 PM
06/18/12 07:19 PM
Ambridge, Pa.
rickraw Offline OP
rickraw  Offline OP
Ambridge, Pa.
checked everything i could except the 6al. finally looked inside the cap. dah, green brass contacts. i think that is the problem. cap isn't that old. anyone else have this issue? maybe some dielectric grease will stop the corrosion. anyone know if a small hole in the cap will help? it's a chev style cap with a window. thanks for ur time.
Re: think i found my miss [Re: rickraw] #1253281
06/18/12 07:53 PM
06/18/12 07:53 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I thought you said you changed cap, rotor and wires..
my cap just has the vent on top
Re: think i found my miss [Re: MR_P_BODY] #1253282
06/18/12 08:36 PM
06/18/12 08:36 PM
Ambridge, Pa.
rickraw Offline OP
rickraw  Offline OP
Ambridge, Pa.
i put a new cap & rotor on for the world finals. so it's not that old. what size hole should i drill in the cap for a vent.
Re: think i found my miss [Re: rickraw] #1253283
06/18/12 09:02 PM
06/18/12 09:02 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Mine has about 3/16" hole in it but it has a cap to
keep rain out.... I would think 1/8" is fine
Re: think i found my miss [Re: MR_P_BODY] #1253284
06/18/12 09:48 PM
06/18/12 09:48 PM
Ambridge, Pa.
rickraw Offline OP
rickraw  Offline OP
Ambridge, Pa.
that's what i thought, thanks. i'll road test it later in the week.
Re: think i found my miss [Re: rickraw] #1253285
06/18/12 10:03 PM
06/18/12 10:03 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
Thats the only bad thing about the bass contacts. If it is that bad,it would not take much for a rotor to arc to the wrong terminal,especially if the rotor phasing is off.
I would think 1/8" hole would be plenty. Not sure on the dielectric grease,I have used WD40 before though with good results.
Keith
Re: think i found my miss [Re: Dunnuck Racing] #1253286
06/18/12 10:06 PM
06/18/12 10:06 PM
Ambridge, Pa.
rickraw Offline OP
rickraw  Offline OP
Ambridge, Pa.
thank u sir, i will try wd40.
