Air Cleaner Spacers #1252878
06/18/12 12:27 AM
06/18/12 12:27 AM
Kent, Wa
340SHORTY Offline OP
Truck Nut
Truck Nut
Kent, Wa
Is there anywhere to get 6 pac carb air cleaner spacers??
I am truckless..
Re: Air Cleaner Spacers [Re: 340SHORTY] #1252879
06/18/12 02:43 PM
06/18/12 02:43 PM
Kent, Wa
Truck Nut
Truck Nut
Kent, Wa
Bumpity bump
I am truckless..
Re: Air Cleaner Spacers [Re: 340SHORTY] #1252880
06/18/12 03:00 PM
06/18/12 03:00 PM
A Banana Republic near you.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
What are you trying to do , raise up the air cleaner ?
Re: Air Cleaner Spacers [Re: JohnRR] #1252881
06/19/12 12:53 AM
06/19/12 12:53 AM
Kent, Wa
Truck Nut
Truck Nut
Kent, Wa
Yeeep.
I am truckless..
Re: Air Cleaner Spacers [Re: 340SHORTY] #1252882
06/19/12 08:54 AM
06/19/12 08:54 AM
Maryland
wally426ci Offline
wally426ci  Offline
Maryland
I have not seen them but my 4 barrel one sucks. ITs plastic and mangles its way crooked....
I plan on switching back out to my 340 air cleaner.
Good luck in the search.
Re: Air Cleaner Spacers [Re: wally426ci] #1252883
06/19/12 11:14 AM
06/19/12 11:14 AM
Kent, Wa
Truck Nut
Truck Nut
Kent, Wa
Im begining to think its a hopeless search..
I am truckless..
Re: Air Cleaner Spacers [Re: 340SHORTY] #1252884
06/19/12 01:04 PM
06/19/12 01:04 PM
I will agree , never seen one before , I think someone asked about one once and got the same results .
now I'll ask ... WHY ???
Re: Air Cleaner Spacers [Re: JohnRR] #1252885
06/19/12 01:21 PM
06/19/12 01:21 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Nope, not hopeless. How thick are you looking for? I wrote a CNC program to make 3/8" spacers for mine. I think I made extras but if they are not the correct thickness for you I still have the program and could make more.
Don't know about the original poster but if you are using the 4782/4783 mechanical carbs the fuel fitting on the front carb hits the bottom of the 70-71 aircleaner base pretty bad. I made 3/8 spacers to fix mine. Still fits fine under a cuda hood.
Re: Air Cleaner Spacers [Re: JohnRR] #1252886
06/19/12 01:39 PM
06/19/12 01:39 PM
Kent, Wa
Truck Nut
Truck Nut
Kent, Wa
I have a fiberglass hood for my 81 shorty. I am putting a lare 60s early 70 Pro Stook style hood scoop on it. I plan on useing 1 of "Paint it Blacks" 69.5 6 pac base. I made my own base years ago and it sits so low that I had to cut the back side to get clearance for the wiper motor. By raising it some I will get more clearance for the base and get it closer to the bottom of the hood.
I am truckless..
Re: Air Cleaner Spacers [Re: 340SHORTY] #1252887
06/19/12 01:57 PM
06/19/12 01:57 PM
GomangoCuda Offline
GomangoCuda  Offline
If you are wanting to raise the aircleaner base up to the bottom of a truck hood then you would need real tallll spacers. Might be easier to make an airbox on the bottom of the hood.
Re: Air Cleaner Spacers [Re: GomangoCuda] #1252888
06/19/12 02:37 PM
06/19/12 02:37 PM
Will too tall a spacer affect the airflow in a negative manner.
Re: Air Cleaner Spacers [Re: JohnRR] #1252889
06/19/12 08:53 PM
06/19/12 08:53 PM
dart1962_440 Offline
Re: Air Cleaner Spacers [Re: dart1962_440] #1252890
06/19/12 09:14 PM
06/19/12 09:14 PM
IN
ahy Offline
ahy  Offline
IN
A real tall spacer will magnify vibration and movement of the engine... the top of that air cleaner will really be moving. The carbs, spacer and/or air cleaner may not be happy with the vibration loading.
Re: Air Cleaner Spacers [Re: ahy] #1252891
06/20/12 05:00 AM
06/20/12 05:00 AM
Kent, Wa
Truck Nut
Truck Nut
Kent, Wa
I have 1 of the Schuemacher torque straps. The engine doesnt move much.
I am truckless..
