Page 3 of 3 1 2 3
Re: Ok so my car is 5 tenths slow [Re: VernMotor] #1252273
06/17/12 05:44 PM
06/17/12 05:44 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
That one guy said on the grudge thread that losing a cylinder will only slow you a tenth. I guess not Glad you got it fixed
Re: Ok so my car is 5 tenths slow [Re: VernMotor] #1252274
06/17/12 06:23 PM
06/17/12 06:23 PM
central ohio
N
nss guy Offline
nss guy  Offline
N
central ohio
Cut the boot off the wire and this is what I found.
you need that get that crap off and put some "Firecore" wires on it and some TTI headers on so you don't burn up any wires.
Re: Ok so my car is 5 tenths slow [Re: nss guy] #1252275
06/17/12 08:25 PM
06/17/12 08:25 PM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
Vern, glad it was tha easy. I am back from vacation !!
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
Re: Ok so my car is 5 tenths slow [Re: sunroofgtx] #1252276
06/17/12 10:04 PM
06/17/12 10:04 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
That the only bad thing about our cammed up hot rods ! Its hard to feel a miss. Glad you got it fixed. Ron
Re: Ok so my car is 5 tenths slow [Re: 383man] #1252277
06/17/12 10:32 PM
06/17/12 10:32 PM
jersey
Spaceman Spiff Offline
jersey
I have an infrared heat gun. When something like this happens, i can use it to test the heat of each header pipe to see what cylinder the miss is in. Helped me to find a broken injector wire on my Daily driver.
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: Ok so my car is 5 tenths slow [Re: Spaceman Spiff] #1252278
06/17/12 10:51 PM
06/17/12 10:51 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
Just glad you got it fixed,Jenni was probably getting worried!
Keith
Re: Ok so my car is 5 tenths slow [Re: VernMotor] #1252279
06/17/12 11:40 PM
06/17/12 11:40 PM
tn
robnbird Offline
robnbird  Offline
tn
Sounds like someone put a two barrel carb and a set of mufflers on it. 3 carbs-2 MSD boxs-2 fuel pumps-3 sets of plugs-cap&rotor. all been change. check valve lash 5 times ! springs look ok not that old-Just took the front of the motor apart everything on the timing chain looks great. also change it from e-85 to gas no change. timing is rock solid. 18-34 .
nothing in the oil filter. compression test good 100-170 . will not rev up..not crisp and clean. What else to check- ideas..split them out !
It still the 100 year old question. Is it getting fuel and ign? sounds like you covered the ign. do you have a carb to try?
Re: Ok so my car is 5 tenths slow [Re: Dunnuck Racing] #1252280
06/17/12 11:52 PM
06/17/12 11:52 PM
Topeka Kansas
K
ksj Offline
ksj  Offline
K
Topeka Kansas
Keith
Best Quote of the entire post!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Re: Ok so my car is 5 tenths slow [Re: sunroofgtx] #1252281
06/18/12 11:02 AM
06/18/12 11:02 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Glad you found the problem Jamie and its a simple fix...
Rich I called your shop the other day to find that
you guys were on vacation... I'll get back with you
Re: Ok so my car is 5 tenths slow [Re: MR_P_BODY] #1252282
06/18/12 11:55 AM
06/18/12 11:55 AM
IN
Irun5snd8th Offline
Irun5snd8th  Offline
IN
A tenth has been my experience in the 1/8th mile with a cylinder down from a plug wire.
AFCO, Rons Fuel Injection sponsored Dodge Challenger Mention Street Lethal Motorsports
Re: Ok so my car is 5 tenths slow (update ) [Re: VernMotor] #1252283
06/23/12 12:43 AM
06/23/12 12:43 AM
Mt.Vernon ,Ohio
VernMotor Offline OP
Mt.Vernon ,Ohio
Car ran 7.14 tonight. so I got my 5 tenths back !
I think how much you lost with a dead hole depends on your HP to weight . me at 500hp with 3900 with me in the car. it hurt
Re: Ok so my car is 5 tenths slow (update ) [Re: VernMotor] #1252284
06/25/12 10:55 AM
06/25/12 10:55 AM
IN
Irun5snd8th Offline
Irun5snd8th  Offline
IN
And that is a very valid point!
Page 3 of 3 1 2 3
