Re: Ok so my car is 5 tenths slow
[Re: CHAPPER]
#1252255
06/17/12 10:20 AM
06/17/12 10:20 AM
Posts: 2,177 ill
dennismopar73
ill
Time for a leak-down test.
i AGREE!
[Re: CHAPPER]
#1252264
06/17/12 12:33 PM
06/17/12 12:33 PM
dartman366
Mt. Vernon, Ohio
had 3 coil on it now.. will do a leak down here today.. compression 120 over 170 .. that is 1 cy. has max 165-170 on all 8. I know some here do not understand 2 numbers on a compression test. you have your first hit then you second hit. Thank you all very much for the repleys
"120 over 170",,,,are you taking it's blood pressure..??
better check for a pulse.
[Re: dartman366]
#1252265
06/17/12 02:55 PM
06/17/12 02:55 PM
Posts: 11,719 Portage,michigan
B3422W5
Portage,michigan
Try another known good battery and make a pass
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
