small, B&M style blower. 440?
#1251892
06/16/12 12:43 AM
06/16/12 12:43 AM
Posts: 4,150 lewiston, ID
cornucopia
lewiston, ID
I have a friend with a B&M blower on his chevy 350. it's an old kit from the 80s. the SMALL blower. I think they advertised then as a "underhood" unit. seems they were on every chevy street rod back then. seeing it got me thinking. my question is, does any company have a kit to put one on a mopar big block? a "bolt on" kit with all the parts...seems like DLI had one many,many years ago, but I havent seen one avaliable lately.
Re: small, B&M style blower. 440?
[Re: DaytonaTurbo]
#1251896
06/18/12 05:50 PM
06/18/12 05:50 PM
Posts: 3,831 N.E. Ohio
6bblFLASH
N.E. Ohio
Yes I have one on a 440. Its an old DLI kit. Took a little more work than I planned but its coming around. Ran a 12.03 @111.44 mph Fri night taking it easy off the line,already broke one driveshaft. It does EXACTLY what it was advertised to do. Adds about 100hp. I figure at best my car would run 13.30`s with out it. Its a STOCK{rebuilt} 440 8.69cr,Stock 10.4 converter,3.55 rear. EST weight 3,800-3,900with driver. New 114c/l .509 cam. I want to try something bigger......someday. If you can accept cutting a hood adapting a blower to a 4bbl intake ain`t impossible. I looked into adapting a Small-Block Chevy intake onto a 440/ SuperStockers did this in the 80`s-90`s when only Chevy`s had good aftermarket intakes.
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas 9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ! 2013 StickShift Challenge Winner@ Mopar Nationals!
[Re: 6bblFLASH]
#1251897
06/18/12 05:55 PM
06/18/12 05:55 PM
6bblFLASH
N.E. Ohio
Oh,,, and it drives and idles like a stocker. Doubt I could have both with just a strong 440. Once you play with boost,you`ll want MORE I DO!!!
[Re: 6bblFLASH]
#1251898
06/18/12 07:49 PM
06/18/12 07:49 PM
Posts: 28,067 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
I've had a turbo 440 since 2001. I'm a boostaholic.
[Re: feets]
#1251899
06/18/12 08:26 PM
06/18/12 08:26 PM
Posts: 4,769 Holland MI Ottawa
2boltmain
Holland MI Ottawa
Many times an Offenhauser dual quad manifold is used to make a blower intake- and thats not just mopars. Ive seen Oldsmobiles with the converted Offy. Now even if you get an Offenhogger 2x4 manifold your still looking at $$$$$$$ to get it converted. In the 80s the B&M pamphlet had that blower kit (small chevy) that would bolt to a single 4bbl intake.
Keep old mopars alive.
