Re: Can this motor be saved?
[Re: Dodgem]
#1251785
06/15/12 11:00 PM
06/15/12 11:00 PM
Posts: 5,449 Woodbridge,CA
NAS Backyard
Woodbridge,CA
First, the guy shouldn't be allowed around tools and yes it can be fixed. .030 is ok . they can bore it back to .030. I just had a sleeve put in a 428 Pontiac 125.00 is the going rate.
1970 Challenger Ragtop 426 4 speed
1961 Olds 88 2 dr Sedan 394 4 speed GVOD
1968 Pontiac Firebird 428 4 speed
2000 Ford F-150
2002 HD Roadking
1961 Licence Plate collection
1995 Buick Roadmaster
www.nogreenautolaws.com
[Re: GregY]
#1251789
06/15/12 11:58 PM
06/15/12 11:58 PM
Posts: 43,721 Bend,OR USA
Cab_Burge
The good Hi Po shops put the ductile iron sleeves in dry ice for a period of time befoe installing(pressing) the sleeves into the cylinders, they also very carefully bore that cylinder out so there is less than .0015 interference fit, they also preheat that cylinder up with a Oxy acetelene(SP?) rosebud tip for several mintues before dropping or sliding the cold sleeve into the block. Let ii sit overnight and then hone all the cylinders, the machinest will, or should know, right away if the other cylinders are distorted or not Go from there
[Re: Cab_Burge]
#1251790
06/16/12 05:37 AM
06/16/12 05:37 AM
Posts: 3,031 Erda, UT
67Charger
Erda, UT
When I lost a cylinder to a random inclusion in the casting finally letting go and creating a .030" pinhole into the #3 cylinder, I had it sonic-checked, sleeved to the +.040 over the other 7 were, touched with a hone on the other 7 to verify still round and give a fresh bite to the new rings ( I re-ringed it while I was in there), decked and line-bored/honed I was out $1100. This block went through the whole gamut to verify everything was going to be right.
11.33 @ 118.46 on motor 10.75 @ 125.35 w/ a little spray Now, high Speed Open Road Racing - Silver State Classic Challenge, Nevada Open Road Challenge, Big Bend Open Road Race Rocky Mountain Race Week 2020, 2022 2.0, Sick Week 2023
[Re: 67Charger]
#1251791
06/16/12 11:08 AM
06/16/12 11:08 AM
For what it could end up costing, you are better off just getting another block.
[Re: ]
#1251792
06/16/12 11:27 AM
06/16/12 11:27 AM
Posts: 75,274 A gulag near you.
JohnRR
A gulag near you.
440 blocks aren't falling out of trees these days , sleeving the one hole and associated costs would be cheaper than starting over ... unless he has to rebore the entire block and buy new pistons , if that is the case start with another block .
[Re: GregY]
#1251793
06/16/12 12:10 PM
06/16/12 12:10 PM
Posts: 4,848 Memphis
HemiRick
Memphis
How far down the cylinder is the hole? Is it down far enough to be past where the rings travel? If so that part of the cylinder doesnt have much pressure on it. I wonder how long a BS fix like some JB Weld in the hole would work? I bet it would work for a while. Or thread the hole and screw in a set screw. Then put some block sealer in it.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: HemiRick]
#1251794
06/17/12 02:59 PM
06/17/12 02:59 PM
Posts: 2,563 God's Country Maryland
GODSCOUNTRY340
As HemiRick stated, if the hole is below the ring travel and not through any water jacket just chamfer the hole and leave it there. Be SURE it is below where all the rings travel.
[Re: GODSCOUNTRY340]
#1251795
06/17/12 03:23 PM
06/17/12 03:23 PM
Posts: 10,931 North Dakota
6PakBee
North Dakota
How big is the hole? If it isn't too large, something like this may work. Look in the crack detection part that covers tapered plug repairs. http://www.irontite.com/manuals/index.php
[Re: GregY]
#1251798
06/17/12 11:15 PM
06/17/12 11:15 PM
Posts: 11,632 SHELBY TWP,,MICHIGAN
72N96RR
I LOVE WEDGIES
I LOVE WEDGIES
1972 Road Runner / GTX 440 4spd Dana 3.54 Just about to turn 26K original miles..
A boat, a GMC truck, some Craftsman Tools, LOTS of Zombie Protection, and a few Goldfish..
If you love someone set them free.. If they come back it means nobody else wanted them either..!!
[Re: dogdays]
#1251800
06/18/12 05:41 PM
06/18/12 05:41 PM
Posts: 1,622 westerly, ri. usa
440lebaron
westerly, ri. usa
freeze plug is pretty low in the block , plug it and jb weld
all parts are sold as is, all parts are considered used no warranties or returns paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred site is not monitored 24/7 there might be a delay in response
