440 sixpack quick change vacuum pods? #1251613
06/15/12 03:54 PM
06/15/12 03:54 PM
southern illinois
O
ozz383 Offline OP
ozz383  Offline OP
O
southern illinois
Everything I read says get the quick change pods,but I cant seem to find them are the ones for the 4150/4160 the same or do the 2300s take a different kit? Thanks ozz
Re: 440 sixpack quick change vacuum pods? [Re: ozz383] #1251614
06/15/12 04:06 PM
06/15/12 04:06 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
2300 is different & I've never seen a Q/C pod for one.... Once you find the right springs you won't need to change it so I wouldn't be to concerned.....
Re: 440 sixpack quick change vacuum pods? [Re: ozz383] #1251615
06/15/12 04:12 PM
06/15/12 04:12 PM
Stuart FL
mercman1 Offline
mercman1  Offline
Stuart FL
A lot of the tricked out vacuum secondary carbs today have an adjustment screw that looks like an idle mixture screw on the passenger side of the carb just ahead of the vacuum pod. This allows you to adjust the timing of the secondarys opening to prevent a bog and get max performance. I sent mine off to Quick Fuel Technology for this mod. This cut my test n tune time at the track down considerably. Instead of changing a spring all you do is turn the screw.
