67 cuda dash issues #1250884
06/14/12 12:02 PM
06/14/12 12:02 PM
Missouri
Clayton Offline OP
Clayton  Offline OP
Missouri
Ive got very dim dash lights on the speedo cluster and no lights on the gauges, also fuel gauge and oil pressure gauge wont work. I pulled the dash and cleaned everything and replaced the circut board that had a burnt spot but no dice. Ive checked all the connections and fuses and wires but I'm out of ideas. Any suggestions? Thanks, Clay
Re: 67 cuda dash issues [Re: Clayton] #1250885
06/14/12 04:32 PM
06/14/12 04:32 PM
North Pole,New York
formula_s Offline
formula_s  Offline
North Pole,New York
The gauges are out because the voltage limiter located inside the gas gauge is fried. Just went through this myself . Changed the gauge and all is well.
