1965 Cuda Rear Axle #125071
09/23/08 01:19 PM
09/23/08 01:19 PM
Anonymous OP
Anonymous OP
I recently pulled arear out of my 65 cuda that was not stock. The rear was a solid axle and there is no inspection plate in the back. It has 10 bolts on the front and can get at the gears that way. The only markings I can see on the axle is the letter X. Anybody know what it came from?
The last owner of the cuda said it was from a satallite.
Re: 1965 Cuda Rear Axle #125072
09/23/08 01:22 PM
09/23/08 01:22 PM
Texas
Daty Rogers Offline
World's Greatest Husband. I love you Robyn
Daty Rogers  Offline
Texas
small bolt pattern or big bolt pattern? Also if you measure between the drums and between the spring perches there is a table here:
http://www.moparts.org/Tech/Archive/axle/17.html
that will help you id the axle in question.
-Daty
Re: 1965 Cuda Rear Axle [Re: Daty Rogers] #125073
09/23/08 01:44 PM
09/23/08 01:44 PM
scratchnfotraction Offline
thats an 8 3/4 rear axle
the # for the center is on the side by the pinion
last 3 digets is what you use to referance them
i.e 741,742,489,
open or sure grips
should have a 4.5 wbp
should be for an 65 A-body but the right b-body is a good swap,and prob what ya buddy used,does he know the gear ratio?
look in the archives for the mesurements on the housings
spring perches been moved to make it fit?
A-body should be 43" centers on the perches,but you can make the 44 center bolt up,look to see if they have been cut and rewelded
measure how wide the housing is frome flange to flange without the backing plates
measure the whole thing axle flange to axle flange
if you pull the chunk the yr and gear will be stamped on the ring gear,and you will know if its an open diff or a suregrip
OH! all most forgot...welcome to the board,lots of info here
Re: 1965 Cuda Rear Axle [Re: Daty Rogers] #125074
09/23/08 01:52 PM
09/23/08 01:52 PM
Anonymous OP
Anonymous OP
Its a big bolt pattern. The stock rear was about an inch shorter that the one in the photo. Thanks.
Re: 1965 Cuda Rear Axle #125075
09/23/08 02:33 PM
09/23/08 02:33 PM
big as in 5 on 4 1/2" wbp not a 5 on 4" A-body wbp..correct?
truck 8 3/4 rear axles have the large 5 on 5 1/2" wbp like ford trucks and the 85 up dodge trucks
I think an early B-body rear is what you have with 44 centers on the spring perches...unless they have been moved
that would bump the wbp up over the a-body 4"wbp
looking at the center section with the yoke in left hand what are the last 3 digets of the # running along the bottom of the pinion?
how long is the housing from backing plate to backing plate?
Re: 1965 Cuda Rear Axle #125076
09/23/08 07:52 PM
09/23/08 07:52 PM
West Tennessee
rbstroker Offline
rbstroker  Offline
West Tennessee
The X is the giveaway. It is a 741 housing 8 3/4. Had one in my '65 Coronet originally.
This is the land of the free because of the brave
Re: 1965 Cuda Rear Axle [Re: scratchnfotraction] #125077
09/23/08 09:52 PM
09/23/08 09:52 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
truck 8 3/4 rear axles have the large 5 on 5 1/2" wbp like ford trucks and the 85 up dodge trucks.
That's only true if the 8.75 came out of a W100.
The D100 used the 5 on 4.5" BP.
