Re: why paint the inside of the block ?
[Re: JohnRR]
#1250164
06/13/12 12:36 AM
06/13/12 12:36 AM
Posts: 6,048 Back home in PA
BulletBob
Back home in PA
To aid the oil draining back to the pan faster. [/quote oil temps go down too
[Re: 1_WILD_RT]
#1250167
06/13/12 01:49 AM
06/13/12 01:49 AM
Posts: 1,655 Cut and Shoot, TX
kentj340
Cut and Shoot, TX
I think the name of the maker is Glyptal, Inc., and they make quite a few different special paints for different purposes. What has been put in engines to aid draining, etc., was originally formulated by Glyptal for painting the innards of power plant generators. Get it for $50 a quart here: http://www.eastwood.com/glyptal-red-brush-on-1-qt.htmlI wonder if Ferraris have this?
[Re: jamesc]
#1250169
06/13/12 03:23 AM
06/13/12 03:23 AM
Posts: 1,187 USA
big-block-dave
USA
I have a '69 440 HP motor that was painted on the inside back in the late 70's....so the idea has been around for quite awhile!!!!!
I'm the CARETAKER of Weinstats '69 440 'cuda registry and have 104 of the 360 cars to date. 84 fastbacks/20 coupes. Always looking for new(REAL M-code) '69 440 'cudas to add to the registry so drop me a note if any are found or known. This isn't a publicly released registry. Thanks, Dave
[Re: 268RTs4ME]
#1250173
06/13/12 09:29 AM
06/13/12 09:29 AM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
Why? Mother Mopar would have done it, if it was GOOD.
Think of it this way - if you don't get a really good stick to the paint it is going to start to lift and peel. Even if you get a good adhere it will still be questionable for how long. Then you will have plugged up mess leading to destruction.
[Re: BulletBob]
#1250177
06/13/12 10:34 PM
06/13/12 10:34 PM
Posts: 10,938 Spokane Valley, WA
Big Bad Bee
Spokane Valley, WA
I think if it were a race block and I was trying to gain every advantage I would look into it, but if it's a street motor and you kept if full of oil, I can't imagine how the payoff would be worth the hassle of getting it right.
I’m listening.
[Re: Big Bad Bee]
#1250178
06/13/12 11:01 PM
06/13/12 11:01 PM
Posts: 43,307 Bend,OR USA
Cab_Burge
I've been using Rustoleum Red Damp Proof Primer to paint the inside of the Mopar blocks ever since Mike Landy told me what it was in one of there old Modified Production race Hemi motors in a Challenger motors at the 1970 or 71 MHRA Winternationals. I use it to seal the lifter valley and timing cover areas after deburring them with a high speed grinder, it seals any tiny cast iron grit residue not washed out after hot tanking the block the final time ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif) It also helps oil drain back some, I've been told ![](/ubbthreads/images/graemlins/shruggy.gif) I worked for a (actually three different ones) phone company for over thirty years, we used Glytol to seal screws and nuts onto electrical switches, just like Loctite does ![](/ubbthreads/images/graemlins/thumbs.gif) Glytol was developed as a sealer and corrosion resistant coating in a very harsh enviorment, oil transformers get very hot and some of that oil is highly toxic ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif) Is it needed, you decide ![](/ubbthreads/images/graemlins/shruggy.gif) BTW, I've never heard of the Rustoleum primer coming off, anything is possible though. I can't say the same thing about the red Glyptol though, I have seen chips of it in a oil filter we cut apart and inspected on one of my motors after being dnyo tested ![](/ubbthreads/images/graemlins/shruggy.gif) I used it once, not anymore after that ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif)
[Re: jamesc]
#1250180
06/14/12 04:04 AM
06/14/12 04:04 AM
BulletBob
Back home in PA
parts left out cost nothing and cause no service problems, how many races have been won because of this procedure
A butt load! Smokey Yunick pioneered it if I remember right & the majority of of winners since the early sixties have most likely used it.
The only time that I've seen it fail was when the block had been sprayed with WD40 after it came out of the vat to keep it from rusting & my buddy who built his own motor & didn't get all the WD washed out of the cast iron.
