Ring gaps for 76 360 #1250107
06/12/12 10:24 PM
06/12/12 10:24 PM
salem, oregon. usa
E
elmor Offline OP
elmor  Offline OP
E
salem, oregon. usa
Rebuilding the 360 in my pickup. Low buck with new cast pistons and cast iron rings. Standard bore. What is the recommended ring end gaps?
Re: Ring gaps for 76 360 [Re: elmor] #1250108
06/13/12 11:43 AM
06/13/12 11:43 AM
.004" per inch of bore on the top ring and .003" per inch of bore on the 2nd ring
Re: Ring gaps for 76 360 [Re: RapidRobert] #1250109
06/13/12 12:54 PM
06/13/12 12:54 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Who's rings? Call them and ask. Newer theory is to make the 2nd ring the same or bigger, to release any trapped gasses that get past the top ring, and to prevent lifting the top ring from too much pressure between the 2 rings.
Error on the side of caution. Too big is no real problem, too small is a huge problem.
**Photobucket sucks**
Re: Ring gaps for 76 360 [Re: 70Cuda383] #1250110
06/14/12 04:33 AM
06/14/12 04:33 AM
salem, oregon. usa
E
elmor Offline OP
elmor  Offline OP
E
salem, oregon. usa
Thanks guys. I would rather be safe than sorry. I only want to do this once.
Re: Ring gaps for 76 360 [Re: RapidRobert] #1250111
06/14/12 04:40 AM
06/14/12 04:40 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I have heard that as well as the theory that a wider second ring gap promotes better ring seal due to less flutter when the second ring encounters pressure from underneath/the crankcase.
I gapped my 440 to .018 top and .22 on the second rings, as per the instructions that came with my rings.
.004 top ring
.0055 second ring.
