Aluminum Radiators, where did u buy yours? #1249686
06/12/12 02:08 AM
06/12/12 02:08 AM
Indiana
maxie Offline OP
maxie  Offline OP
Indiana
For those running aluminum raditors what brand is it? Are you happy with it?
I have a Mancini aluminum 26 inch in the road runner and I am very happy with it. I am now looking to buy one for the demon, which is a 22 inch radiator support and hoping it will cool the hemi.
Re: Aluminum Radiators, where did u buy yours? [Re: maxie] #1249687
06/12/12 02:54 AM
06/12/12 02:54 AM
Canada
CrAzYMoPaRGuY Offline
Canada
I bought a 26" Champion 3 core for my Charger (mild 440) and it seems to run COOL so far.... but it ain't summer here yet!
CrAzYMoPaRGuY
Re: Aluminum Radiators, where did u buy yours? [Re: maxie] #1249688
06/12/12 05:59 AM
06/12/12 05:59 AM
places
79powerwagon Offline
places
Mine was the affordable Summit unit for "Ford". Fit nicely and cooled just fine!
Re: Aluminum Radiators, where did u buy yours? [Re: maxie] #1249689
06/12/12 09:11 AM
06/12/12 09:11 AM
PA
noplanb Offline
noplanb  Offline
PA
26 in Wizard with dual Spal fans, no problems cooling a 560 HP 493 with air.
remember when you said honey, some day that car is gonna look so good in front of our house
Re: Aluminum Radiators, where did u buy yours? [Re: noplanb] #1249690
06/12/12 09:18 AM
06/12/12 09:18 AM
Seaford Delaware
JSR1485 Offline
JSR1485  Offline
Seaford Delaware
I have bought 2 Wizard Cooling Radiators both 22" one for a Scamp I had and the other For my Duster, they bolt right in and accept the factory fan shroud. Top notch workmanship on their radiators.
Switched to the dark side...
Re: Aluminum Radiators, where did u buy yours? [Re: JSR1485] #1249691
06/12/12 11:13 AM
06/12/12 11:13 AM
Urbana, MD
bordin34 Offline
bordin34  Offline
Urbana, MD
I got a 26" 2-row Champion from a guy on here, JonGottaDemonDad.
Re: Aluminum Radiators, where did u buy yours? [Re: maxie] #1249692
06/12/12 12:16 PM
06/12/12 12:16 PM
Houston, Texas
racerx20 Offline
Standard but OK
racerx20  Offline
Standard but OK
Houston, Texas
I am also in the wizard camp. It was more expensive than some but well worth it in fit and finish. The stock shroud bolted right up.
1972 Road Runner
1988 Shelby CSX-T
Re: Aluminum Radiators, where did u buy yours? [Re: maxie] #1249693
06/12/12 05:09 PM
06/12/12 05:09 PM
Champion 2 row for my 65 dart from an eBay seller in Tustin California. $169.95 & free shipping. It'll be here tomorrow or thurs. His chart said direct fit . Nipples are in the correct locations.
Re: Aluminum Radiators, where did u buy yours? [Re: RapidRobert] #1249694
06/12/12 06:04 PM
06/12/12 06:04 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Mine is an Afco that I bought from Mancini. It works good. Ron
Re: Aluminum Radiators, where did u buy yours? [Re: 383man] #1249695
06/12/12 06:13 PM
06/12/12 06:13 PM
Andrewh Offline
Andrewh  Offline
I was a little paranoid about cooling. Went with 4secondsflat and ordered the dual pass. had to have the brackets welded on once I figured out where they needed to be. Am very happy with the cooling.
but having both inlet and outlet on the same side is a bit bad, and no transmission cooler.
Though I have learned to live with both. The first because I swapped engines and got over it, the second because a lot of people don't recommend using the coolers built into rads anymore anyway.
Re: Aluminum Radiators, where did u buy yours? [Re: Andrewh] #1249696
06/12/12 09:07 PM
06/12/12 09:07 PM
North Dakota
Azzkikrcuda Online content
Azzkikrcuda  Online Content
North Dakota
Wizard Cooling radiator in mine. Works great.
Re: Aluminum Radiators, where did u buy yours? [Re: Azzkikrcuda] #1249697
06/13/12 12:07 AM
06/13/12 12:07 AM
Wherever I am.
Junky Offline
Junky  Offline
Wherever I am.
Recently installed a Griffin 26" radiator with 1 1/4" tubes. Very happy with it except that when I received it, it had scratches on the top, one deep. That to me is inexcusable. I guess their quality control ain't so good.
2010 Black Challenger SE <> 3.5 V6
Custom Shift Knobs www.flameball.com Check It Out
Re: Aluminum Radiators, where did u buy yours? [Re: maxie] #1249698
06/13/12 12:41 AM
06/13/12 12:41 AM
Arizona
GreenGlow Offline
GreenGlow  Offline
Arizona
Chamion from the guy selling them on here in the parts section.
I got 2 four core radiators from him. One for my 512 Challenger and 1 for my 493 Roadrunner. Both are using Ford Contour electric fans we've only reached 90 degrees here so far but both are staying cool.
Re: Aluminum Radiators, where did u buy yours? [Re: Junky] #1249699
06/13/12 12:44 AM
06/13/12 12:44 AM
Glendale Az
Darryls-Demon Offline
Glendale Az
I have two cars with Ron Davis radiators. Both work very well but for what they cost they should.
Re: Aluminum Radiators, where did u buy yours? [Re: Darryls-Demon] #1249700
06/13/12 02:18 AM
06/13/12 02:18 AM
Philadelphia
radar Offline
radar  Offline
Philadelphia
My northern works great in front of a stroked small block.
Re: Aluminum Radiators, where did u buy yours? [Re: radar] #1249701
06/13/12 08:02 AM
06/13/12 08:02 AM
Doniphan, Nebraska
Lmopar69 Offline
Lmopar69  Offline
Doniphan, Nebraska
I put a Champion in my Cuda and my Challenger. The Cuda stays cool even in heavy traffic at over 90 degrees outside here in South Alabama and I drive it 70+ miles a day to and from work.
Both fit perfectly and ya cant beat them for the price IMO. I wouldnt call them "show quality", but they look good enough for a normal car.
Laine.
NRCA Member
Re: Aluminum Radiators, where did u buy yours? [Re: maxie] #1249702
06/13/12 08:12 AM
06/13/12 08:12 AM
Pendleton NY
terzmo Offline
terzmo  Offline
Pendleton NY
Champion Radiators
Re: Aluminum Radiators, where did u buy yours? [Re: terzmo] #1249703
06/13/12 06:23 PM
06/13/12 06:23 PM
North Riverside IL & Lowell IN
GTXKen Offline
super gas
GTXKen  Offline
super gas
I ordered a wizard last week, not cheap but from what I have seen well worth it. A good buddy of mine runs one so he did the beta for me.
Re: Aluminum Radiators, where did u buy yours? [Re: GTXKen] #1249704
06/13/12 10:40 PM
06/13/12 10:40 PM
Spokane Valley, WA
Big Bad Bee Offline
Big Bad Bee  Offline
Spokane Valley, WA
A buddy of mine here purchased a Champion for his 70 Charger. Drove it down to Hot August Nights in Reno last summer. It was scorching hot out. I believe he's got 3.91's, 440 tunnel ram. Engine stayed cool the whole trip.
I’m listening.
Re: Aluminum Radiators, where did u buy yours? [Re: Big Bad Bee] #1249705
06/13/12 11:11 PM
06/13/12 11:11 PM
IN
ahy Offline
ahy  Offline
IN
Mancini "Muscle Car" top tank aluminum for me. It cools a warm 496 wedge with AC just fine.
