Re: Anti-Roll Bar for a Leaf Spring Car???
[Re: StrokerAspen]
#1249633
06/12/12 12:49 AM
06/12/12 12:49 AM
Posts: 52,972 Romeo MI
MR_P_BODY
S&W has what you need... the tube is welded to the frame with the splined arms... has 2 adjuster links that drop down to heims that go into brackets welded on the diff.... they have all different lengths... you would need to call them... they arent in the on line catalog
[Re: MR_P_BODY]
#1249634
06/12/12 01:49 AM
06/12/12 01:49 AM
Posts: 1,600 Alberta Canada
StrokerAspen
Alberta Canada
Thanks Mike! Of Course you have an answer. LOL. I should have just PM'd ya! What size of diameter should I be looking at? 7/8" or 1-1/8"??
-Kenny
[Re: StrokerAspen]
#1249635
06/12/12 09:20 AM
06/12/12 09:20 AM
MR_P_BODY
-Kenny
I ordered the 1 1/8 to put on a customers chassis but if yours doesnt twist or roll over alot, the smaller bar is fine(thats what I put on my race car)
[Re: StrokerAspen]
#1249636
06/12/12 10:18 AM
06/12/12 10:18 AM
Posts: 12,395 Taxes & Virus's R-US, NY
Dragula
For leaf springs, that is a new one on me, but we installed one of the S&W splined anti roll bars on the race car, with a four link, and it works very well. Post pics if you go this route.
[Re: StrokerAspen]
#1249638
06/12/12 01:36 PM
06/12/12 01:36 PM
Posts: 4,569 Motor City
6PKRTSE
Motor City
Yes, leaf spring cars run them to. Do a google search. The fastest cars in the country are running them with good results. I have one on my 70' Challenger. Not the best picture but it is all I have right now for a picture of the set up.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: 6PKRTSE]
#1249639
06/12/12 01:56 PM
06/12/12 01:56 PM
Dragula
Don't get me wrong, I am sure it will have the same effect as it does on our four link car, but is it needed? We needed it because we had nothing to control roll the higher up we chipped it.
It also doesn't look like your fully tubbed. I would never be able to fit it on my E-body with mono's and Caltrac's. Heck, the wheelie bars barely clear. And on our A-body, there isn't any room for wheelie bars. Thankfully we don't need them, but the anti-roll bar works very well.
[Re: Dragula]
#1249640
06/12/12 02:02 PM
06/12/12 02:02 PM
6PKRTSE
Motor City
No, my Challenger is not fully tubbed. Only mini-tubbed to the frame rails. It is all that I will need. I still can get a 315 D.R. or a 29.5 x 10.5W on it with 12" wheels. I agree. it is still very tight in there for everything. Still may add wheelie bars some day.
[Re: StrokerAspen]
#1249642
06/12/12 05:31 PM
06/12/12 05:31 PM
MR_P_BODY
Thanks for the picture! I mounted my shocks almost exactly the same way, so I could probably do something similar to your anti-roll bar.
-Kenny
I like to use brackets for multi purpose use so I would weld the axle anti roll brackets to the back of the link brackets(forward of the shocks)...JMO
[Re: Dragula]
#1249643
06/12/12 08:12 PM
06/12/12 08:12 PM
Posts: 6,145 Melbourne , Australia
LA360
As it is on a 4 link, an Anti Roll is another tuning aid. With a factory floor it gets tight for room with running one, but with a big horsepower car it is almost a must nowadays. JMO anyway
Alan Jones
[Re: MR_P_BODY]
#1249650
06/12/12 09:51 PM
06/12/12 09:51 PM
StrokerAspen
Alberta Canada
I make it mandatory to put one on a 4 link if I'm building the chassis
Yeah, and with the leaf link set up under the car, the only thing that is holding it somewhat straight, is the back segment of the 6 cylinder leaf springs.
Another thing I noticed watching my videos from each side of the car, The passenger side squats as soon as the trans brake is let go. The body immediately drops. From the drivers side the diff seems to fall out of the car, until the shock tops out, and yanks the back end down. My link bars are set the same side. My instant center SHOULD be the same on both sides of the car. I guess as the power hits, it is twisting the car, thus moving the instant center on the driver side above the anti squat line, and putting the passenger side further under the anti squat line. Am I on the right track? I would assume an anti-roll bar is going to keep the instant center more constant side to side when the power is applied no?
I have the front segment of my stock leafs clamped with an extra 3/8" thick leaf added to the front segment. If I unclamp this added leaf, It will drop the back of the car down another 3/4-1" lower, thus putting my instant center lower than it currently is under the anti-squat line. The leaf spring does not need to be clamped anymore for strength, I did the extra leaf years ago when none of the leaf link stuff was on the car. Unlike the original leaf link design, I have added a bar that runs along the top of the leaf from my diff mount plate, to the front spring eye. If you look close in the pictures i have posted, The leaf is not twisted at all because the bottom bar is taking all of the hit.
-Kenny
[Re: StrokerAspen]
#1249651
06/12/12 10:02 PM
06/12/12 10:02 PM
MR_P_BODY
-Kenny
The axle is trying to roll around the drive shaft... the right side is trying to lift up and the drivers side is dropping out... I'm sure thats what your seeing plus some twisting in the body
