Page 1 of 3 1 2 3
did 1968 coronets w/ 4-speed have 318 engines?found car #124908
09/23/08 05:02 AM
09/23/08 05:02 AM
las vegas, nevada
bugsydog Offline OP
bugsydog  Offline OP
las vegas, nevada
I'm going to look at a car this afternoon that is my buddys, his father died in an accident recently and informed me about this car that his father has owned since new and from what he says is in great original condition. At this time the info is a 68 coronet w/4 speed and a big engine. I was wondering without knowing if its an R/T or 500 was it possible to have a 4 speed behind any type of motor for that year?
Re: did 1968 coronets w/ 4-speed have 318 engines?found car [Re: bugsydog] #124909
09/23/08 07:44 AM
09/23/08 07:44 AM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
Yes. You could get a 383 two or four bbl four speed in a 68 Coronet Deluxe, 440 or 500 model. No four speed behind the 318.
Seeking:
1969 St. Louis plant VINs, SPD, and VONs.
Over 2,000 thanks to you!
Re: did 1968 coronets w/ 4-speed have 318 engines?found car [Re: bugsydog] #124910
09/23/08 10:31 AM
09/23/08 10:31 AM
Arizona
68CoronetRT Offline
68CoronetRT  Offline
Arizona
Get the VIN and the first two letters will tell you the Model:
WH = Coronet 440
WP = Coronet 500
WS = Coronet R/T
The 5th letter will tell you the engine:
F = 318
G = 383
K = 440
J = 426
H = 383 hi performance
The R/T came stock with a 440 engine and the only option was the 426 Hemi.
According to my 68 manual the Coronet 500 would be the 318 engine. However as previously stated no 318 engine with the 4 speed.
Re: did 1968 coronets w/ 4-speed have 318 engines?found car [Re: 68CoronetRT] #124911
09/23/08 10:59 AM
09/23/08 10:59 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
440 eng code = L
Re: did 1968 coronets w/ 4-speed have 318 engines?found car [Re: 68CoronetRT] #124912
09/23/08 11:00 AM
09/23/08 11:00 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
WH = Coronet 440
WP = Coronet 500
WS = Coronet R/T
F = 318
G = 383
K = 440 Actually that would be a L.. K is 350 hp 440 used in C bobies, L is 375 hp 440 (Magnum)
J = 426
Re: did 1968 coronets w/ 4-speed have 318 engines?found car [Re: bugsydog] #124913
09/23/08 11:57 AM
09/23/08 11:57 AM
Snowing in the north!
Dart 340 Offline
moparts member
Dart 340  Offline
moparts member
See if he has a build sheet on it. If he bought it new he just might!
Anything was possible with Chrysler....
Re: did 1968 coronets w/ 4-speed have 318 engines?found car [Re: Dart 340] #124914
09/23/08 12:37 PM
09/23/08 12:37 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Maybe it's actually a 318/3 speed and he's just mistaken over the # of gears the trans has?
Re: did 1968 coronets w/ 4-speed have 318 engines?found [Re: Dart 340] #124915
09/23/08 12:46 PM
09/23/08 12:46 PM
Gabba Gabba Hey! NYC
Diego (not Ted) Offline
Oh, brother!
No one has mentioned the 361-2, which was available with a 4-speed. If I'm off in that this engine was not available in 1968 (god, my brain is going . . .), then it's gotta be a 383-2, which was available with a 4-speed through 1968.
Re: did 1968 coronets w/ 4-speed have 318 engines?found [Re: Diego (not Ted)] #124916
09/23/08 12:48 PM
09/23/08 12:48 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
361 was gone by 68...I think 66 was the last year...318 3spd is very possible...
Re: did 1968 coronets w/ 4-speed have 318 engines?found [Re: Diego (not Ted)] #124917
09/23/08 01:14 PM
09/23/08 01:14 PM
Dart 340 Offline
moparts member
Dart 340  Offline
moparts member
Oh, brother!
I'm not touching this one anymore.......LOL
Re: did 1968 coronets w/ 4-speed have 318 engines?found [Re: Dart 340] #124918
09/23/08 01:57 PM
09/23/08 01:57 PM
Oh, brother!
68 Coronet SS 427...
Re: did 1968 coronets w/ 4-speed have 318 engines?found #124919
09/23/08 02:36 PM
09/23/08 02:36 PM
wisconsin
1BAD68 Offline
1BAD68  Offline
wisconsin
either way, 68 Coronets are nice unless its a four door.
Good luck!
Re: did 1968 coronets w/ 4-speed have 318 engines?found car [Re: bugsydog] #124920
09/23/08 02:49 PM
09/23/08 02:49 PM
las vegas, nevada
bugsydog Offline OP
bugsydog  Offline OP
las vegas, nevada
I just got back from looking at the car it's a 68 500. i could not get to the vin onlt the fender tag
WP23 62 3 31 117 224274
P6C 001 U
Re: did 1968 coronets w/ 4-speed have 318 engines?found car [Re: bugsydog] #124921
09/23/08 03:01 PM
09/23/08 03:01 PM
las vegas, nevada
bugsydog Offline OP
bugsydog  Offline OP
las vegas, nevada
now if i'm correct the 62 is a 383 4 barrel. The car does need to be restored, drivers fender in front is a little damaged, and the passenger fender is wrinkled behind the wheel opening, interior need to be redone, paint is original but needs to be repainted. For being a 383 4 speed and all #s matching what is this thing worth?I was told buy the widow the day he came back from vietnam he went down and puchased this car new off the showroom floor.
Re: did 1968 coronets w/ 4-speed have 318 engines?found car [Re: bugsydog] #124922
09/23/08 03:07 PM
09/23/08 03:07 PM
las vegas, nevada
bugsydog Offline OP
bugsydog  Offline OP
las vegas, nevada
pics, motor not in car at this time
Re: did 1968 coronets w/ 4-speed have 318 engines?found car [Re: bugsydog] #124923
09/23/08 03:08 PM
09/23/08 03:08 PM
las vegas, nevada
bugsydog Offline OP
bugsydog  Offline OP
las vegas, nevada
another
Re: did 1968 coronets w/ 4-speed have 318 engines?found car [Re: bugsydog] #124924
09/23/08 03:08 PM
09/23/08 03:08 PM
las vegas, nevada
bugsydog Offline OP
bugsydog  Offline OP
las vegas, nevada
last one
Re: did 1968 coronets w/ 4-speed have 318 engines?found [Re: bugsydog] #124925
09/23/08 03:11 PM
09/23/08 03:11 PM
Danville, NH
Mopar_Mike Offline
Mopar_Mike  Offline
Danville, NH
IMO.. doesn't matter what its worth.. BUY IT! Its not everyday one comes across such a deal... And of course if you prefer not let me know..
RS23L7 4-Speed
Re: did 1968 coronets w/ 4-speed have 318 engines?found [Re: Mopar_Mike] #124926
09/23/08 03:15 PM
09/23/08 03:15 PM
Manitoba, Canada
Manitoba, Canada
Looks in good shape to me. I'd buy it, put it back together and run it as a survivor for a while.
Re: did 1968 coronets w/ 4-speed have 318 engines?found [Re: DaytonaTurbo] #124927
09/23/08 03:19 PM
09/23/08 03:19 PM
Beautiful car. I would be all over it, good color, the way it is optioned it is basically an R/T with a 383, the trim level is the same 4 speed is a good plus.
Grab it before the word gets out.
Page 1 of 3 1 2 3
