Master Cylinder Question - '72 Charger #1248828
06/10/12 11:11 PM
06/10/12 11:11 PM
Two Harbors, MN
chrgr340 Offline OP
chrgr340  Offline OP
Two Harbors, MN
Long story short, my '72 Charger (manual brakes) needs a master cylinder. It is the all steel one with 4 mounting holes. I've heard that there is one with a plastic reservoir that requires either little or no modification to bolt on to my car. Is this true? If so, what do I need to get one off of? Any insight is appreciated.
1972 Dodge Charger - F7, Rallye pkg, 340, A833
2007 Dodge Charger R/T R&T - 12sec daily beater
1999 Dodge Dakota R/T - M1, cam, heads, T56 swap
1997 Dodge Dakota - 318, NV3500, 3.92 Sure Grip
Re: Master Cylinder Question - '72 Charger [Re: chrgr340] #1248829
06/11/12 12:56 AM
06/11/12 12:56 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
The plastic reservior master cylinders are also aluminum bodied, saving more weight. They use a 2 bolt mounting flange, but adapters are commonly available. An adjustable pushrod is used to make up for the thickness of the adapter.
Contact Doctor Diff. He has everything and nobody here ever complains about him.
Re: Master Cylinder Question - '72 Charger [Re: Kern Dog] #1248830
06/11/12 01:02 AM
06/11/12 01:02 AM
AndyF Offline
AndyF  Offline
The adjustable pushrod isn't required but it doesn't hurt to have one. If you have a manual brake pushrod it should work just fine.
