Timing belt question #1248566
06/10/12 07:05 PM
06/10/12 07:05 PM
USA
JoesMopar Offline OP
USA
What is generally more important in determining when to change a timing belt: The age of the belt or the mileage on the belt?
The car is a 2000 Intrepid with ~60,000 miles. Still runs great and is all original and in great shape, I was just curious as I'm planning on going through the car this fall.
Re: Timing belt question [Re: JoesMopar] #1248567
06/10/12 08:56 PM
06/10/12 08:56 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
60k , change the belt .
in this case I would go by both the age and mileage of the belt , the general consensus is 60k , change the belt , It could last longer but if it's an interference engine I would not chance it , nor wait till fall unless it's going to be parked till then .
Re: Timing belt question [Re: JoesMopar] #1248568
06/10/12 08:57 PM
06/10/12 08:57 PM
Port Reading, NJ
roadrunner7070 Offline
Port Reading, NJ
Thank god I don't have to worry about that. BMW still uses a timing chain! 1989 with 145,000 miles with no change.
Re: Timing belt question [Re: roadrunner7070] #1248569
06/10/12 08:58 PM
06/10/12 08:58 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
I do mine at 30-35K, I have an interference fit head. Tim
Re: Timing belt question [Re: JoesMopar] #1248570
06/10/12 09:52 PM
06/10/12 09:52 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Assuming it's the 3.2 or 3.5, every one I removed at 100-150k mi looked great still. They are a nice wide belt. I would consider putting a quality water pump on there at same time, whatever you decide.
Re: Timing belt question [Re: astjp2] #1248571
06/10/12 09:55 PM
06/10/12 09:55 PM
Catskill, NY
teflon Offline
teflon  Offline
Catskill, NY
Factory interval, service B is 100,000 miles.
