Trans cooling question...
#124809
09/22/08 09:18 PM
09/22/08 09:18 PM
Posts: 4,431 Michigan
MarkZ
Worthy
Worthy
I was at the local you-pick-it parts place yesterday and scored some nice trans coolers for 10 bucks. They are of the stacked plate design and I'm not sure which to run. I've been wanting to bypass the cooler that is in the radiator and I'm not sure which way to go with this now.
I've got two of the thinner coolers, and one of the thick one. They're both the same length and width, 7"x11.5". The thicker one is 2" deep, and the thinner two are 1" deep.
I was thinking of running the two smaller ones together at first, and then came across the big one. What would be the most efficient, the two smaller, or the one large cooler?
Re: Trans cooling question...
[Re: MarkZ]
#124811
09/23/08 08:54 AM
09/23/08 08:54 AM
Posts: 845 Kansas
64Belvedere
super street
super street
Kansas
Personally, I'd run the big one and call it good. With two coolers, there's extra hardline to bend up and additional headaches with mounting the second cooler.
[image][/image]
[Re: earlybee]
#124817
09/25/08 03:02 PM
09/25/08 03:02 PM
MarkZ
Worthy
Worthy
I probably should have posted more details on the setup. Car has an A500 in it with a 2400 TCI lockup converter.
Seeing as how I live in Michigan then I'll definitely leave the stock cooler inline.
Is it harder to flush the stacked plate coolers? I was just going to run mineral spirits through it with a couple of pounds from a blow gun behind it. I figured I'd do that until the mineral spirits came out clean on the other end.
[Re: MarkZ]
#124818
09/25/08 03:21 PM
09/25/08 03:21 PM
Posts: 10,218 Someplace you aren't
SomeCarGuy
I wouldn't run a used cooler from a car I didn't know.
If you want to end cooling problems try running syn. ATF. Costs a boat load, but if you overheat it your car will be on fire anyway so it won't matter.
I want my fair share
[Re: MarkZ]
#124819
09/25/08 06:46 PM
09/25/08 06:46 PM
RapidRobert
I've used those spray cans of flush made for trans lines/coolers from a parts store
