6-pak throttle position adjustment #1248009
06/09/12 08:12 PM
06/09/12 08:12 PM
Ripley, NY
tcat446 Offline OP
tcat446  Offline OP
Ripley, NY
Hello all !!
First post here. Can anyone tell me how to go about adjusting a throttle sensor bolted to the manifold on my 70 Cuda 6 pak? Thank you in advance. Looks like a nice site!!
Re: 6-pak throttle position adjustment [Re: tcat446] #1248010
06/09/12 08:20 PM
06/09/12 08:20 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
Hello all !!
Welcome aboard! are you referring to the idle solenoid under the center carb linkage?
Re: 6-pak throttle position adjustment [Re: mikemee1331] #1248011
06/09/12 09:47 PM
06/09/12 09:47 PM
FLA
JohnnyBee Offline
JohnnyBee  Offline
FLA
Re: 6-pak throttle position adjustment [Re: mikemee1331] #1248012
06/09/12 10:29 PM
06/09/12 10:29 PM
Ripley, NY
tcat446 Offline OP
tcat446  Offline OP
Ripley, NY
Hello all !!
Yes, I am. It doesn't move when the key is on. Is it suppose to?
Re: 6-pak throttle position adjustment [Re: tcat446] #1248013
06/09/12 10:34 PM
06/09/12 10:34 PM
South San Francisco, Ca
70sixpkrt Offline
70sixpkrt  Offline
Here is a description of the solenoid:
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: 6-pak throttle position adjustment [Re: 70sixpkrt] #1248014
06/09/12 10:39 PM
06/09/12 10:39 PM
70sixpkrt Offline
70sixpkrt  Offline
And this:
4-speed
3:54 Dana
Re: 6-pak throttle position adjustment [Re: tcat446] #1248015
06/09/12 10:40 PM
06/09/12 10:40 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
Hello all !!
yes, it is. here is a link to a link that has alot of great info and a truly awesome website. https://board.moparts.org/ubbthreads/showflat.php?Number=6940589
Re: 6-pak throttle position adjustment [Re: mikemee1331] #1248016
06/09/12 10:51 PM
06/09/12 10:51 PM
Ripley, NY
tcat446 Offline OP
tcat446  Offline OP
Ripley, NY
WOW !! I goggled this for an hour. Got more info here on this subject than I ever imagined. Thank you everyone!!!! Now I see how this is suppose to work.
I will try to figure out how to post some pics of it. Been a 12 year project. Yes, 12 years, but its done and its home. Long story.
Re: 6-pak throttle position adjustment [Re: tcat446] #1248017
06/10/12 12:25 AM
06/10/12 12:25 AM
Ripley, NY
tcat446 Offline OP
tcat446  Offline OP
Ripley, NY
Not moving when the key is on. What should I check? Anyone know what it should ohm out at? Is it just 12 volts? Is there a fuse for it?
Re: 6-pak throttle position adjustment [Re: tcat446] #1248018
06/10/12 07:53 AM
06/10/12 07:53 AM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
it's 12 volts and doesn't have a seperate fuse. i would run a test wire from your battery and bump the power terminal to verify it's working.
Re: 6-pak throttle position adjustment [Re: mikemee1331] #1248019
06/10/12 11:34 AM
06/10/12 11:34 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
And if it has power it still wont work unless the throttle is open enough to take pressure of the plunger.The solenoid wont lift the arm,it is designed to hold the arm up after the arm is lifted and solenoid engaged.
Re: 6-pak throttle position adjustment [Re: 62maxwgn] #1248020
06/10/12 05:02 PM
06/10/12 05:02 PM
Ripley, NY
tcat446 Offline OP
tcat446  Offline OP
Ripley, NY
Got it guys! Thanks for all the help!
