installing a msd box on a car that ha d leanburn #1247930
06/09/12 05:16 PM
06/09/12 05:16 PM
Minneapolis, MN
moparguy Offline OP
moparguy  Offline OP
Minneapolis, MN
Im putting a msd box on my new yorker to dit ch leanburn. What im wondering is on the small red wire. The directions say to hook it to the cars coil pos. Wire. Now being as im tryong to bypass the leanburn, can i still hook it to this wire? Or should i find another switched 12v source?
Thanks!
Re: installing a msd box on a car that ha d leanburn [Re: moparguy] #1247931
06/09/12 07:03 PM
06/09/12 07:03 PM
Philadelphia
radar Offline
radar  Offline
Philadelphia
It's just a trigger for a relay any switched 12v + will do.
Don't forget to swap out the distributor- the leanburn ones are locked out. Some carbs have electronic enrichment and run like doo-doo without the LB computer. I did the conversion on my /6 pickup a few years ago.
Re: installing a msd box on a car that ha d leanburn [Re: radar] #1247932
06/11/12 03:34 PM
06/11/12 03:34 PM
Minneapolis, MN
moparguy Offline OP
moparguy  Offline OP
Minneapolis, MN
thanks radar, I have the vacuum advance distrib to toss in as well as a new edelbrock carb to put on. I need to run a 1/2" spacer to let it work, since the throttle linkage was hitting on the stock intake.
