Re: Help with harmonic balancer ID ?
[Re: 440newport]
#1246022
06/06/12 12:00 AM
06/06/12 12:00 AM
Posts: 104,346 Garden Grove, CA
OzHemi
Penguin-hating Ginger
Garden Grove, CA
Thanks for that ![](/ubbthreads/images/graemlins/thumbs.gif) I had got it with a big block pan with the idler arm notch, but wasn't sure if the balancer was off the same engine or not. It does have the one offset hole in it as well...
[Re: Cab_Burge]
#1246024
06/06/12 05:28 PM
06/06/12 05:28 PM
OzHemi
Garden Grove, CA
Thanks Cab ![](/ubbthreads/images/graemlins/biggrin.gif) I got the timing cover with it too actually.. ![](/ubbthreads/images/graemlins/laugh2.gif) (the guy had the balancer, timing cover, and one of the oil pans with the idler arm notch in it...along with some other stuff I had wanted at the swap meet so I ended up just doing a cheap package deal on the lot of it ![](/ubbthreads/images/graemlins/laugh2.gif) )
