Re: Clearances
[Re: beepbeepdon]
#1245784
06/05/12 02:27 PM
06/05/12 02:27 PM
dartman366
Mt. Vernon, Ohio
on my 408 Terry set the clearances at .0030-mains,,,.0028 on the eagle rod's, so you are pretty close in my opinion.
Re: Clearances
[Re: beepbeepdon]
#1245786
06/05/12 02:48 PM
06/05/12 02:48 PM
Posts: 43,248 Bend,OR USA
Cab_Burge
Loose or tight?......Any opinions?
main bearing clearances .00275 rod bearing clearances .00250
That is tight in my opinion, tighter than I like to use in a race only motor If you used a thin oil,5W20 or zero weight, you'll probally be fine with those clearances, make sure you have some heat in the oil before racing it though I like to have between .003 to .004 on the mains and .003+ on the rods using the 2.200 rod journal size, bigger on the stock Mopar rod sizes, 2.375 I use 5W20 or 5W30 wt. oil only in all of my motors now, street or race only
Re: Clearances
[Re: Cab_Burge]
#1245788
06/05/12 03:48 PM
06/05/12 03:48 PM
Posts: 99 USA
BB Dart 69
USA
I use 30wt oil,
Re: Clearances
[Re: beepbeepdon]
#1245789
06/05/12 05:20 PM
06/05/12 05:20 PM
Posts: 52,972 Romeo MI
MR_P_BODY
That almost exactly what my 416 clearances are... I normally run .003 and .003 ... I wouldnt worry about it... if you run heavy oil you'll see high pressures
Re: Clearances
[Re: BB Dart 69]
#1245793
06/05/12 07:01 PM
06/05/12 07:01 PM
Cab_Burge
I use 30wt oil,
I'll share a little information on oil wieght based on past dyno testing, motor #1 with 30 WT oil saw a ten HP increase in the oil temps being 130 F versus raising them to 160 F Motor # two and later saw no HP or Torque differences with both 5W20 WT and 5W30 WT between 90 F and 200 F A ten HP change at the track can throw your dial off a bunch
