Re: How can I fix my Speedo?
[Re: cbusters]
#1245465
06/04/12 07:42 PM
06/04/12 07:42 PM
Posts: 2,806 Northern NJ
StukaJU87
Northern NJ
start here
[edit] see you are a 4 spd.
Scott
1969 Super Bee, 383/4 speed
[Re: cbusters]
#1245466
06/04/12 07:46 PM
06/04/12 07:46 PM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
You need the diameter of the tire and gear ratio to find out which gear you need. Look in the tech archives. IIRC theres a chart there that will help you. Being a 3.73 is not a Mopar factory ratio you may need to compromise by picking a a gear choice to get close to what you need. Id suggest a gear that makes the speedo register a tad fast for a MPH cushin on the highway..
I am truckless..
[Re: cbusters]
#1245468
06/04/12 08:35 PM
06/04/12 08:35 PM
RapidRobert
I laid a piece of flat stock across one of my rear tires & measured the ACTUAL dia then used the chart in the archives along with my rear gear ratio to pick the right speedo gear. at the interstate mile markers I went exactly a mile on my odo (go 5 miles) which tells me my selection was correct and my speedo read correct at a roadside digital MPH sign which told me the magnetic gismo in the speedo head was already calibrated correct. I have been advised that rollout feet/inches is more accurate but dia worked for me.
