Indy 440-1 Throttle Bracket/Cable #1245445
06/04/12 07:11 PM
06/04/12 07:11 PM
Auburn Hills, Michigan
K
kieron_kohlmann Offline OP
K
I have a set of Indy 440-1's on my super bee and am looking for a throttle cable bracket/cable to use. Does anyone know what will fit/work? the stock one is too short.
Re: Indy 440-1 Throttle Bracket/Cable [Re: kieron_kohlmann] #1245446
06/05/12 01:48 AM
06/05/12 01:48 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
i made my own bracket & mounted it off the carb studs.
Re: Indy 440-1 Throttle Bracket/Cable [Re: rebel] #1245447
06/05/12 01:49 AM
06/05/12 01:49 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
my earlier 4150 series carb mount.
Re: Indy 440-1 Throttle Bracket/Cable [Re: kieron_kohlmann] #1245448
06/05/12 03:57 AM
06/05/12 03:57 AM
AR Engr makes a really nice throttle bracket for the Indy intakes and heads, adjustable to You can buy them from Mancini and Hughes, I think
Re: Indy 440-1 Throttle Bracket/Cable [Re: kieron_kohlmann] #1245449
06/05/12 11:11 AM
06/05/12 11:11 AM
AndyF Offline
AndyF  Offline
www.arengineering.com and look in the center of the page.
Re: Indy 440-1 Throttle Bracket/Cable [Re: kieron_kohlmann] #1245450
06/05/12 11:15 AM
06/05/12 11:15 AM
an8sec70cuda Offline
I like the Lokar cables and CSR billet brackets.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Indy 440-1 Throttle Bracket/Cable [Re: an8sec70cuda] #1245451
06/05/12 01:45 PM
06/05/12 01:45 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I use Lokar also with my EZ heads and an 850 Carb. I like it as you dont need a bracket since the bracket bolts to the carb. Ron
