Need help with 727 #1245193
06/04/12 10:33 AM
06/04/12 10:33 AM
Ohio
440727 Offline OP
440727  Offline OP
Ohio
Ok my little brother has a 1979 Dodge aspen.
He just had his transmission rebuild using a 727 non lock up rebuild kit. I find out its a lock up 727.
Does he need to tear it back apart ?
Is there an easy fix just to make it a non lock up trans ?
What's the best route ?
Thanks !
Re: Need help with 727 [Re: 440727] #1245194
06/04/12 10:44 AM
06/04/12 10:44 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
What issue is he having ?
Re: Need help with 727 [Re: JohnRR] #1245195
06/04/12 09:19 PM
06/04/12 09:19 PM
Ohio
440727 Offline OP
440727  Offline OP
Ohio
Since he used a non lock rebuild kit is there any key areas that might have not been included in the kit ? I've heard seals in the pump are different ?
He has a non lock up torque converter which I'm guessing will not work in a lock up transmission ?
Re: Need help with 727 [Re: 440727] #1245196
06/05/12 09:41 AM
06/05/12 09:41 AM
JohnRR Offline
JohnRR  Offline
The parts are basically the same. Most rebuild kits come with all the seals to cover a multitude of years and both types of the trans. The lockup differences are the input shaft assembly, the front pump, the valve body and the convertor, everything else is the same, clutches and such don't care which trans convertor type it is. The converters DO NOT interchange, don't try to put it on it may get stuck.
