I assume you have a hydraulic cam ?
Pay a good shop to test the load rate of closed and open pressures. Buy a spring with a closed rate of 100-105 lbs and a open rate close to 280lbs, at your installed spring height from the spring seat to the bottom of the retainer. just my opinion for better valve control. With stock 3/8 OD stem heavy valves the extra spring load is needed and will not hurt the cam with good oil.
How close are you to South Houston Engine ? They are a good shop. I've been there on business a few times for Radiac abrasives and they can do the job.
MLR426
