Re: brake pedal to the floor
[Re: junkyardkid]
#1244050
06/02/12 01:01 PM
06/02/12 01:01 PM
Posts: 369 California, USA!!!
WheelsUp73
California, USA!!!
where do i start?
after sitting for a year, my 71 scamp started right up, however i had no brakes. i checked all fluids before cranking, full resevoir of brake fluid, any tricks or hints please? thanks in advance
Put a mastercylinder on it and check the wheel cylinders for seapage.
[Re: junkyardkid]
#1244051
06/02/12 01:03 PM
06/02/12 01:03 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
Bleed everything. Start at master first
Drums? Make sure shoes are adjusted and that your pedal stroke isn't taken up just pushing them back out
Also if power brakes, make sure the adjuster rod inside the booster is out and making contact on the master cylinder piston.
My dads van has had a soft pedal since he put it back together, 4-5 inches of pedal travel before any braking happened.
Just last week I was helping him look it over. Found that threaded rod was about 1/4" too short! He had no idea that was a point of adjustment, or that he needed to check it!!
**Photobucket sucks**
[Re: 70Cuda383]
#1244052
06/02/12 04:29 PM
06/02/12 04:29 PM
Posts: 21,088 Niles , Ohio
therocks
Niles , Ohio
All the answers and no questions.Did the brakes feel and work normal when it was parked?If they did then adjustment would mean nothing.Does the pedal come up when you pump the brakes?Id almost have to agree a bad master and or a blown line if they dont pump up.Typicallly a wheel cyl will freeze from sitting making a grabby brake.It would be a good idea to check them also anyway.Rocky
Chrysler Firepower
