Connecting rod side clearance
#1243874
06/01/12 11:56 PM
06/01/12 11:56 PM
Posts: 1,210 Rochester, New York
GregY
Rochester, New York
Guys,
I am disassembling my 440, which has overheated a couple of times, once pretty badly.
I measured my connecting rod side clearances prior to pulling the pistons, and was getting in the 0.026"-0.030" range, and the spec is 0.017" or less. Could this have been causing my excessive oil consumption after the bad overheating episode?
How do you fix this, buy wider connecting rods?
Thanks.
Greg
Re: Connecting rod side clearance
[Re: GregY]
#1243875
06/02/12 12:00 AM
06/02/12 12:00 AM
Posts: 2,006 s. e. pa.
calrobb2000
s. e. pa.
hi that is one speck you do not have to worry about ! many here run much more side clearance with no problems . i have .025 for the last 20 years on a motor an it runs perfect ! ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: GregY]
#1243876
06/02/12 12:00 AM
06/02/12 12:00 AM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
It's good to pay attention to specs, the rod side clearance spec however is one number that virtually never comes up in spec yet never causes any issues either.... Fact is guys putting Chevy rods on Chrysler cranks wind up with upwards of .060 clearance & I've never heard of a problem caused by it....
[Re: 1_WILD_RT]
#1243879
06/02/12 09:03 AM
06/02/12 09:03 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
It's more like "minimum of .017".
More has not been a problem on anything I've done, and I've NEVER seen it below .017, except the one time I needed chamfered bearings for the small block with a forged eagle crank, and the bearings that were supplied we're standard bearings. Once the new bearings arrived, the side clearance was up around .025
**Photobucket sucks**
