Re: video tease.
[Re: hemi-itis]
#1243563
06/02/12 10:47 AM
06/02/12 10:47 AM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
Tease alright,not even a little GOOSE
I know!if the ATF was not spraying all over the floor i would have let the parts get warm and blipped it for ya.I spliced the trans line togather untel i get a cooler and will try again today to check the fluids and any leaks and my A/F from drilling out the int circuit in the carb for more fuel.
Re: video tease.
[Re: racer_amx]
#1243565
06/02/12 02:49 PM
06/02/12 02:49 PM
Guitar Jones
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
Re: video tease.
[Re: Guitar Jones]
#1243566
06/02/12 05:08 PM
06/02/12 05:08 PM
Clanton
northern,Ohio,USA
Well she got up to temp but the temp gauge is not working[mechanical]i must have pinched the line so i will need to swap out that for an EGT probe,new gauge,trans temp gauge.The neutral safety wire came off the relay and a plug wire was not all the way on the #8 plug so now i can move on to other things.[Idle rpm/mix,start watching the LM-1/LC-1,put a Y fitting in the intercooler line[supply side]and start tunning for that A/F so it will stay running with just tap water running.I dont want to PO the neighbors so that is it untel monday for vids.If you have a question just ask. http://www.youtube.com/watch?v=c6POMQLjbpM
