1050 DOMINATOR!!???? #1242630
05/31/12 02:37 AM
05/31/12 02:37 AM
louisville,kentucky
moparmangolf Offline OP
louisville,kentucky
Maybe, Somebody can help me we hooked the fuel lines from the regulator to the carburetor and the back gas comes out of the bottom of the carburetor when you turn the on the fuel pump and we have six pounds of fuel pressure we swapped the lines from the regulator and stil when you turn on the fuel pump gas comes out under the base plate by the rear two barrells CAN SOMEONE PLEASE HELP MOPAR MANIA!!!??????
Re: 1050 DOMINATOR!!???? [Re: moparmangolf] #1242631
05/31/12 03:55 AM
05/31/12 03:55 AM
Sacramento, CA
cal_gecko Offline
cal_gecko  Offline
Sacramento, CA
post photos of how you've got fuel lines hooked up , just to verify you're not plugged into a vacuum port or something...
Re: 1050 DOMINATOR!!???? [Re: cal_gecko] #1242632
05/31/12 06:20 PM
05/31/12 06:20 PM
Joplin, Mo
rt66jim Offline
rt66jim  Offline
Joplin, Mo
Could be a stuck needle & seat assy. Or could be a bad float.
Re: 1050 DOMINATOR!!???? [Re: moparmangolf] #1242633
05/31/12 06:51 PM
05/31/12 06:51 PM
Take the needle and seat out and look real closely with a magnifier at the black Viton seat on the needles to see if there is any garbage or debris caught in it If so clean it out, if not look to see if there is a ring indented in it, if so replace the needle and seat BTW, make sure and buy a .120 or bigger needle and seat to avoid fuel starvation, Dominators need a lot of feul volume
