No Start #1242441
05/30/12 08:59 PM
05/30/12 08:59 PM
lake county, ca
lake71383 Offline OP
lake county, ca
Ok guys I have a quick question. I went out the this morning to start my wagon wouldn't start so I did a couple thing and it started after wigging the shifter linkage, took it out and it started good all day and now it won't start I tried everything I could thing of. Thank you for any help.
Re: No Start [Re: lake71383] #1242442
05/30/12 09:29 PM
05/30/12 09:29 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Have you tried holding the key in the start position and moving the shifter from Park to neutral? I took it that you meant wouldn't turn over rather than won't start. Two different things that diagnose entirely differently.
Re: No Start [Re: stumpy] #1242443
05/30/12 11:24 PM
05/30/12 11:24 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
i read it that way too.
Re: No Start [Re: mikemee1331] #1242444
05/31/12 12:24 AM
05/31/12 12:24 AM
lake county, ca
lake county, ca
Sorry about that been a long day. No it will not turn over.
Re: No Start [Re: lake71383] #1242445
05/31/12 01:36 PM
05/31/12 01:36 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
If moving the shifter through the pattern doesn't work then stick your head under the car and see if the NSS plug is plugged in.
Re: No Start [Re: stumpy] #1242446
05/31/12 01:46 PM
05/31/12 01:46 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
and being engaged. if yes to both suggestions, then the switch needs to be pulled and checked.
