440 engine Chip #1242081
05/30/12 12:03 PM
05/30/12 12:03 PM
gainsville, usa
johnfin Offline OP
johnfin  Offline OP
gainsville, usa
I accidently chipped the deck of this 440 while smashing out frozen pistons. Its into the bore but not into the ring area. Could this pose a problem?
Re: 440 engine Chip [Re: johnfin] #1242082
05/30/12 12:09 PM
05/30/12 12:09 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
You're going to have it bored/honed anyway, right? So any "lip" protruding into the cylinder will be cut down level... also make sure it doesn't stick up above the deck.
If you're sure it's well above the top ring travel, the other problem might be the head gasket fire ring. If the head gasket bore is large enough, should be ok.
Re: 440 engine Chip [Re: johnfin] #1242083
05/30/12 12:11 PM
05/30/12 12:11 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Since you are going to bore it I doubt it will be an issue. just make sure it's nice and smooth inside the bore.
Coming soon!!!!
Re: 440 engine Chip [Re: Mr.Yuck] #1242084
05/30/12 12:31 PM
05/30/12 12:31 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
make sure whatever head gasket you're going to use will seat properly in the chipped area
Re: 440 engine Chip [Re: jamesc] #1242085
05/30/12 03:12 PM
05/30/12 03:12 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Just make sure your head gasket goes around the chipped area, and does not overlap it. If you're boring it, there might not be much or any of that chip left after anyway.
