HEI conversion distributors?
#1241700
05/29/12 11:20 AM
05/29/12 11:20 AM
Posts: 847 Parsons (SouthEast) Kansas
funkyjbp
mopar addict
mopar addict
Anyone have experience with the Ebay HEI conversion distributors? I just bought a 50 Studebaker truck with a 360 in it. the wiring is nightmare and cannot get spark now. I have a new 5 pin harness and ballast fabbed up so i can run engine separate of the main wiring harness. Still no luck. the ebay distributors are cheap enough and would eliminate some wiring and bulk under the hood. the truck has new paint and interior and runs great when it is actually running. There are two styles, one with a traditional HEI cap but it's huge and i don't think it will clear my firewall. the second type uses an MSD-looking male terminal cap that clips on like an OEM Mopar cap. any advice? I know they are cheaply made and not Mopar parts but do they work well enough is what i asking. thanks, JP in the land of Oz.
71 SWB, 413
77 SWB, 318
92 SWB, 5.2 magnum
79 Macho Short bed, 318
03 stratus coupe R/T
too many others not on the road!
Re: HEI conversion distributors?
[Re: funkyjbp]
#1241701
05/29/12 01:06 PM
05/29/12 01:06 PM
Posts: 1,074 detroit, mi
POS Dakota
detroit, mi
You dont need the ballast with HEI.
Both units are fine. The smaller one needs an external coil, the larger one has the coil inside, yet eliminates need or a coil wire.
All you need is one keyed on connection to run the large one and the other one you need one power wire and the coil.
A lot of people are using these with success and a small percentage report problems mainly with bushings, though I hve never seen any evidence myself.
[Re: POS Dakota]
#1241702
05/29/12 01:13 PM
05/29/12 01:13 PM
funkyjbp
mopar addict
mopar addict
POS, I've seen your username out there relative to this issue. If i can clear the firewall, i would rather use the standard HEI cap design for simplicity. i am doing a mock-up measurement tonight to see if the cap will clear. i am setting an HEI cap down over the stock distributor with spacers on each side to center it as best i can. i have about an inch and half from the current cap to the firewall now and i will need about 1 inch additional space to the rear. thanks for info. JP in the land of Oz.
71 SWB, 413
77 SWB, 318
92 SWB, 5.2 magnum
[Re: funkyjbp]
#1241703
05/29/12 02:25 PM
05/29/12 02:25 PM
POS Dakota
detroit, mi
You're welcome.
I like the large cap unit because everything is in it and they've always worked well for me. if it will fit, that's definitely the one I would use. Clean with only 1 wire hookup and they give a nice strong reliable spark.
[Re: DaytonaTurbo]
#1241705
05/30/12 11:31 AM
05/30/12 11:31 AM
funkyjbp
mopar addict
mopar addict
well i broke down and ordered a new Proform unit with the traditional HEI cap and coil combination. it's a one wire hook-up which will be a clean installation on my truck. I got a new polished billet distributor, new federal mogul 8.8 HEI wires ready to install and autolite plugs delivered for 140$. that's cheaper than buying all new mopar ignition parts (coil, distributor, cap, rotor, wires, plugs, ecu, ballast and wiring). If it clears firewall in my Studebaker, I'm good. thanks for advice. JP in the land of Oz.
71 SWB, 413
77 SWB, 318
92 SWB, 5.2 magnum
