neural safety switch question. #1241503
05/29/12 03:13 AM
05/29/12 03:13 AM
Oklahoma
TinCuda Offline OP
TinCuda  Offline OP
Oklahoma
1971 'Cuda 440 727 auto
I turned the key = nothing.
12 volts at yellow wire to start relay with key turned.
Jumped start rely and engine started right up.
Ran a jumper wire from brown wire on start rely to negative battery post and engine started with key.
I figure open wire from starter relay to neutral safety switch.
Anyone have a picture of where to look before I get out the floor jack and start crawling around under my car?
(O O {]{]{]||[}[}[} O O) 1971 Plymouth 'Cuda 440-6 {||O||} 2000 Yamaha V-Max (O O [========= SRT] O O) 2011 Dodge Challenger SRT 392 . Making as big as a carbon footprint as I can!!!
Re: neural safety switch question. [Re: TinCuda] #1241504
05/29/12 04:20 AM
05/29/12 04:20 AM
Philadelphia
radar Offline
radar  Offline
Philadelphia
It's easy to find- just look for the only wires coming off the transmission and going back up to the firewall. Im not sure which style you'll have. Did you try starting in N as well as P?
Re: neural safety switch question. [Re: radar] #1241505
05/29/12 01:20 PM
05/29/12 01:20 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
You may just have a linkage adjustment problem.
