Re: Stock vs Aftermarket Torsion Bars
[Re: DusterJeff]
#1241468
05/30/12 03:22 PM
05/30/12 03:22 PM
Posts: 1,168 Vancouver, WA
MoparMarq
Vancouver, WA
Yep....I am installing PST,s Polygraphite suspension rebuild kit in the front end right now.
That will help in removing some of the slop in component movement.
I am wondering if .160 thousandths thickness in the bars is worth the $200.00 plus cost of the bars if it will make the car handle better.
Spring rate is not a linear relationship to T-bar diameter. Upping your bars from the .840" diameter (along with appropriate shocks to control them, as a previous poster said) will make a big difference in handling, response, and possibly even braking, to a small degree.
Will the front end height be improved also??????
You'll still have the adjusters in the control arms, so you should still be able to set ride height (in the front anyways) where you want.
